What's the perfect engine for the 4*60?
My 4*60 has clipped wing, much larger rudder and elevator. Here is what I want it to do; take off point straight up climb about 50 feet, pull it over on to its back, angle it down then 1/2 roll to up right followed by a nice touch-n-go! Ok maybe I'm dreaming but you get the picture. This type of flying sounds more suited to a 4 stroke (YS 91 maybe). How are the two strokes (OS 91 maybe) at slower aerobatic flying on the 4*60?
Marcus |
I don't have a 4*60 but alot of the guys in our club have them and they all use Saito FA100's. A really good match!
mwright
1 Attachment(s)
i just finished my 4* 60 and bashed it the same way, I have on hand a saito 80 but its going on my proctor antic bipe when its completed , but will be on the star for break in , (and until i can afford the correct engine) which is the 100 as posted already. PS here's a pic of mine , I luv to show it off :D :D :D
I cut one rib bay from each wing and rounded the wingtips; also increased the rudder 1 inch and rounded all the tail tips - just like the looks of rounded tips better.
I flew it with a Saito .91 4 stroke for a year and it did OK. Then needed the 4s for something else and put an OS .61FX in the 4*60....WOW, what a difference. It is a beautiful flying plane and will do all I ask. Put a .91fx in it, and it will not quit going up, but I think that's overpowering it. George |
Im Flying mine with a 91 FX and 15/6 apcs. It is truley awesome. Not way overpowered, but just about perfect. I flew it for fun in an IMAC contest because I lost my Edge the day before to a radio glitch. The judges scored me and I took 1st place in Sportsman IMAC. The plane is just way fun with the 91. You can as I qoute
"take off point straight up climb about 50 feet, pull it over on to its back, angle it down then 1/2 roll to up right followed by a nice touch-n-go!" if you really wanted to. Well any decent engine and you will have fun with it. I have all the coupling mixed out and you can knife edge from horizon to horizon. Hope this helps. |
mix
fishgod - Could let us in on the mixes that you use?
Marcus |
4*60 usa a Enya 90 4 strokeer, flys where ever you point it.
Just don't aim at a tree like i did |
| All times are GMT -8. The time now is 11:50 AM. |
