RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Bridi Sun Fly V (https://www.rcuniverse.com/forum/kit-building-121/394035-bridi-sun-fly-v.html)
Kaos Rulz 12-02-2002 11:49 AM
Bridi Sun Fly V
Builders,
Who knows what the purpose of the slots (fore and aft) in the ribs of the Sun Fly V are for? Could they be for some type of jig. I''ve seen holes drilled in ribs to accomodate wire jigs, but never slots. Can anyone help me out? I'm also trying to figure out the best way to build this wing. There are no blocks to shim the wings' trailing edge to secure proper wing taper.
Any suggestions will be appreciated. Thanks in advance,
ED
edhaeuser 12-03-2002 05:32 PM
Bridi Sun Fly V
I just built a set of wings for a Bridi Killer Chaos. It also has the slots you speak of. I have heard of people using music wire in the slots as a jig. However, I followed Bridi's instructions and drew a line on each rib front to back using the slots as reference to the centerline of the rib. When building the wing, pin the top (most likely) spar to the plans, put the ribs in place on the spar (do not glue yet) and block the rear of each rib (you have to cut your own blocks) with a wood block. slide the blocks for and aft until each rib center line is parallel to the building surface. I tacked each block in place with a small drop of ca where it touches the rib. Next, I believe I glued the trailing edge in place, making sure that all ribs were perpendicular and parallel to the surface. This is a start, If you have any questions feel free to email me.
Ed H
Kaos Rulz 12-04-2002 12:13 PM
Bridi Sun Fly V
Thanks for your response Ed. I did just as you described and while it was a little time consumming, it worked very well with the music wire as a guide. I'm confident that the wing is true. Thanks again.
ED
firemedic305 12-26-2002 11:04 PM
eazy to build jig
1 Attachment(s)
I just built a jig for my chaos wing it is easy and quick. use 1/16 3/4 angle and old scrap 2x4s used a 2x2 stock to keep every thing plumb squar and level.
