building first kit
im building my first kit well my second i did one with my dad whe i was real litle so i dont remember, any ways what do i need as in supplies ot build it like glue,hobby knife that sorta thing lmk thnx. Also it as a sig cadet mark II
RE: building first kit
exacto knife
razor saw T-pins 4" x 12" sanding block -- cut it out of 3/4" pressed countertop particle board thin CA thick CA 30 min. epoxy covering iron heat gun building board workbench -- LEVEL and SQUARE!! Not some warped POS coffe table you dug out of grandmas basement incidence meter (?) allen wrenches 12" level screwdrivers corless drill LIGHTS!!! -- working in the dark sucks straight edge ruler metal square hinge slotter wax paper loctite dremel tool and attachments CG machine (?) -- I just use my fingertips on a trainer velcro strips for battery and RX latex foam for padding the RX 3/8" paint brushes for spreading epoxy That should get you started. [sm=thumbup.gif] |
nice list
now for the low buget list What I used to scrach build my first plane a kadet Sr. any larg flat serface check with a stright edge in all directions a sheet of drywall wax paper exacto knife I cut hing slots with it razor saw T-pins screwdrivers allen wrenches stright edge a drill and drill bits your just drilling balsa and ply a cheep set will work thin CA thick CA epoxy covering iron heat gun is nice but you can get by with out it sanding block Small square foam padding Im sure iv left some thing out Danny |
Hi eightball. Welcome to the incredibly rewarding world of modeling! The SIG Kadet Mk II was my first R/C kit, too. So you should turn this thread into a build thread and post any questions you have along the way. There's lots of help around here and don't worry about what you think might be a "dumb" question. It's better to do it right than guess and goof up.
If you think you will be building more planes after this one - and I really hope you do, this hobby needs more modelers - I highly recommend you invest in a balsa building board like this one: http://www2.towerhobbies.com/cgi-bin...?&I=LXVZ63&P=7 It may be the best $20 you ever spend. Also get a good assortment of sandpaper, some single-edged razor blades and #11 X-acto blades. Rcpilet covered most everything. Needle-nose pliers and a set of 1/16" through 1/4" drill bits will get used a lot, and a set of hex wrenches, too. Let us know how the project progresses. David |
Hey guys
I am going to piggyback here a little. I am going to build a four star 40. This will be my first kit. This list of stuff will be vary helpfull. As a newbie I gota start somewhere. Happy flying Weathervane |
Hello to all. I have been flying for years. I love it, it is a true passion of mine. I started flying in the 8th grade with a Zagi 400 and I got the bug. I started out in nitro with a small .15 size 3ch ARF. I kept moving up in engine sizes and I built a .15 size kit sport plane that was a blast to build. I joined the Navy after high school and after I got in I didnt have tons of time to build or fly being on the ship. I am now on shore duty and I want to build a good first/second kit and I have dreams of moving up to giant scale wirbirds someday. Got any ideas of what would be a few good kits to get my building skills up to par? Any advice would be great. Thanks for listening. Take care, Jon
| All times are GMT -8. The time now is 03:36 PM. |
