Superchipmunk radio setup
I'm just about ready to install my radio, and I had a few questions.
I built the model with flaps, I'm going to use a jr 537 for those. 2 jr 537's for aileron servo's as well. jr 507 for throttle What do I use for rudder? I've heard of a few poeple suggesting a high torque servo for the rudder. What do I do for the elevator? do I really need 2 servo's (one for each half?). I joined the halfs togther with the rod, thick CA, and glass tape (to renforce the wire install) Can I use a 537 on that as well? Rgds, Theo Aftonomos ps: also let me know if my intended servo tasks (aileron, throttle, flaps) will work out well please. |
1 Attachment(s)
If your talking about the Goldberg Chipmunk, I use (2) 3101's (Futabas version of the mini servo) on the elevator, and S148's on the rudder and each aileron. I do not have flaps. You may want to put more torque on the rudder, but I seem to have plenty with the S148.
Ryan |
I should have mentioned: I have a pull-pull set up on the rudder.
Ryan |
thanks
Thanks for the info.
GREAT looking airplane! btw, is that a glass cowl? wheel pants too? |
Yea. The cowl and pants are fibreglass from Stans fibretech. Stan does some outstanding work! Did away with the plastic bellypan; built it up with balsa as part of the wing.
Saito .91 for power makes an excellent combination. Ryan |
| All times are GMT -8. The time now is 01:21 PM. |
