forming windshields
I need to make windshields for my Sterling Waco SRE and a 1/6 scale Sig Cub. Would greatly appreciate advice on how to do it.
THanks |
forming windshields
Cut a template from paper. Keep trimming or recutting until you have the desired shape, then transfer the shape to some clear plastic and cut it out.
forming windshields
great idea, i will try it.
Thanks for the reply |
forming windshields
If you need some heat to make the bends hold the plastic in your bare hand and use a heat gun. If your hand can take the heat you probably will not be harming the plastic.
Dave Segal |
| All times are GMT -8. The time now is 10:25 PM. |
