Stangel designed/cut kits
Anybody familiar with Stangel kits? Suggestions are welcome.....I am looking at the follwing kit
SKYLARK SPORT 40 KIT Aerobatic Radio Control Model Airplane Pre-Cut Kit For Experienced Builders that prefer choosing their own hardware and components to build airplanes. Balsa wood, plywood, basswood built-up construction. We supply all the wood necessary for completion. 95% of parts are machine pre-cut for fast and easy assembly. Rolled CAD plans, limited instructions, suggested component list included. General Info Wingspan 48" Wing area 490 sq" Length 38" Weight 3.5 lb Full width ailerons Full Symmetrical Airfoil Solid fuselage sides Solid tail feathers Removeable cowl Removeable wing INCLUDED IN KIT Full-size CAD plans Over 80 Pre-Cut parts Braces and gussetts Wing sheeting Rib caps Plywood firewall Plywood LG mount Wing hold-down tabs Basswood servo rails Basswood elevator joiner Balsa wheel pants parts |
RE: Stangel designed/cut kits
I bought the .60 size Hornet biplane Stangel offers based on the praise a friend of mine has for the larger size version of the Skylark. He has since framed it up and it is awaiting covering -- says a lot of material can be removed on the corners because of the thick construction used throughout. Looks like very nice materials: machine cut and hand selected for grain/density to use in appropriate areas -- even has the right smell when you open the box. He enjoyed building it so much, he split shipping with me for a bipe kit as well. The Stangel site says something to the effect of temporary delay in production while switching over to laser cutting? Won't be getting to mine too soon because of other projects.
Dave |
ORIGINAL: H5606 Won't be getting to mine too soon because of other projects. Dave |
Where can I find a SKYLARK SPORT 40 KIT?
Try [link]http://www.stangel.com/[/link]
as a side note, he has this posted on the website - Announcement - Our RC and CL model airplane kits are being redesigned for laser-cutting. Our kits will not be available until this redesign and testing is complete. You might try sending him an email to see if any are still available. |
| All times are GMT -8. The time now is 11:27 PM. |
