RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Su-Do .60 so far (https://www.rcuniverse.com/forum/kit-building-121/57311-su-do-60-so-far.html)
wgeffon 02-18-2002 09:14 PM
Su-Do .60 so far
1 Attachment(s)
Certainly not the best building kit I have even seen but, heres the progress so far.
PaulSwany 02-19-2002 06:21 PM
Su-Do .60 so far
Looks nice Wayne... You said "not the best building kit".. What didn't you like about it?
wgeffon 02-19-2002 06:38 PM
Su-Do .60 so far
For starters, look here.
http://www.rcuniverse.com/showthread...&referrerid=60
I asked Robert at Morris about this and all he could say was " yeah the instructions suck dont they? Want to re-write them for us?"
I did get the e-mail address to the guy who wrote them for this kit and he really didnt have any advice either.
I'll figure it out. Its just frustrating.
I also had to replace all the 1/16 sheeting cause it was unusable..
aaa-RCU 02-20-2002 03:05 AM
Su-Do .60 so far
Hi Wayne,
Is that the 1/16 sheeting for the wing? Was the sheeting warped?
Also, do you have any other pictures of the kit under construction to post?
Thanks.
wgeffon 02-20-2002 03:08 AM
Su-Do .60 so far
Yes, Thats the sheeting for the wings.
I am halfway through the wings at this point. WOW! There has to be an easier way.......Read, read and then re-read the instructions for the wings.
I keep telling myself that it will all be worth it once its in the air.
wgeffon 02-20-2002 05:53 AM
Su-Do .60 so far
1 Attachment(s)
Heres a few pics of the wing.
wgeffon 02-20-2002 05:54 AM
Su-Do .60 so far
1 Attachment(s)
aaa-RCU 02-20-2002 12:26 PM
Su-Do-Khoi stress
I believe that there should be an easier way. :confused: I have stopped building my kit as it is too fustrating to continue right now. I believe that building should be fun and a remedy for stress, not the cause of it. :(
In the mean time, I am cheating a bit by assembling my H9 CAP232 ARF with Saito 1.80. :D Want to go flying with it this weekend to remove some of my Su-Do-Khoi stress.
wgeffon 02-20-2002 02:18 PM
Re: Su-Do-Khoi stress
I am the type of person that has to just plug away till its done. If I put it away half finished, knowing that there are problems, it will just gnaw at me till I get back to it.
I know once its flying it will be worth the effort...... :rolleyes:
wgeffon 02-22-2002 05:29 AM
Su-Do .60 so far
1 Attachment(s)
A little more progress today.
aaa-RCU 02-22-2002 12:19 PM
Throttle control
Hi Wayne,
Are you using pushrods for the throttle or a cable?
P.S. The kit is looking good. Keep it up!! :)
wgeffon 02-22-2002 02:51 PM
Su-Do .60 so far
1 Attachment(s)
For the throttle I am using a Nyrod. Red outer tube yellow inner.
I did have to figure out a way to reverse the direction of the throttle linkage at the engine. ( typical with 4 cycles )
Heres what I did.
wgeffon 02-23-2002 10:05 PM
Su-Do .60 so far
1 Attachment(s)
Just needs to be sanded and covered now.
Chris 540 02-23-2002 11:09 PM
Su-Do .60 so far
Do any of the servos get stuck in the fuse or are they all in the wing?
wgeffon 02-24-2002 12:42 AM
Su-Do .60 so far
Chris,
The throttle, rudder and elevator servos are in the fuse.
Chris 540 02-24-2002 12:46 AM
Su-Do .60 so far
Is the kit so bad you wouldn't recommend it?
wgeffon 02-24-2002 03:56 AM
Su-Do .60 so far
Chris,
Hmm. Tough question.
I would say definately not a first or second kit. If all someone is used to is Sig or GP kits (where they spoon-feed you in the instructions) this isnt a good kit at all. You really need to be able to evaluate the whole plane as its going together making sure you dont screw yourself later. You need to really think about stuff like, If I do ....... now am I going to be able to do ............ later.
You have to be able to do things on your own and not rely on the instructions.
The plans are hard to read. Lines are where they shouldnt be and some lines that should be there aren't. The wood pretty much sucked. Example, hold two 5/16 square pieces together and they arent the same size. Close, but not exact.
Sheeting was warped. Some of the die cutting on the lite-ply wasnt even halfway through the sheet.
It will all be worth it once its in the air. They hover extremely well. SUPER stable. Reminds me of some of the planes out there for G2.
Should be done in a week or so.
Chris 540 02-24-2002 04:25 AM
Su-Do .60 so far
Yea...I've built a Topcap...wasn't too bad though...
I've seen a guy fly a 60 So Do and it was extremely stable...his 40 size So Do is not even close to being as stable. Maybe I can grab it from him...He had a 91 FX and pipe on it. The 60 size that is...
aaa-RCU 02-26-2002 11:21 PM
Su-Do .60 so far
Wayne
Have you completed the Su-Do-Khoi as yet? Looking for some more pictures of the finished product.
wgeffon 02-26-2002 11:47 PM
Su-Do .60 so far
Not much to look at right now. I am going to start covering tonight or tomorrow.
wgeffon 03-03-2002 03:21 AM
Su-Do .60 so far
1 Attachment(s)
One wing panel done.
Top.
wgeffon 03-03-2002 03:23 AM
Su-Do .60 so far
1 Attachment(s)
Bottom.
Not fun to do but, it looks good.....
Nathan 03-03-2002 04:22 AM
Su-Do .60 so far
oooh... I like what I see, wanna sell it? :D
Looks great so far Wayne! Keep the pics coming.
wgeffon 03-03-2002 04:25 AM
Su-Do .60 so far
Originally posted by Plane Insane
wanna sell it? :D
Not yet....... :D
wgeffon 03-04-2002 05:14 AM
Su-Do .60 so far
1 Attachment(s)
More wing pics.
