RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Building The PT40 (https://www.rcuniverse.com/forum/kit-building-121/5911099-building-pt40.html)
dan876 05-28-2007 06:30 AM
Building The PT40
Hi, my name is Dan.
As my first plane I will build the PT40.[8D][8D][8D]
I would like to have some sugestions about the building.
Alex7403 05-28-2007 10:51 AM
RE: Building The PT40
Hi Dan,
[8D]
welcome, good to see you on RCU.
Alex
pt40crasher 05-28-2007 03:02 PM
I built the 'sport' wing and was glad I did. If I were to build another PT, I would take more dihedral out and the wash-out as well. I would also build it as a tail-dragger. Rig as much aileron travel as possible. This is a great airplane but like most trainers it is treacherous in a crosswind. They are very resilient airplanes and can take tons of abuse. Have fun.
http://i24.photobucket.com/albums/c8...r/100_0831.jpg
RIP
carrellh 05-28-2007 03:09 PM
I built the PT-60, which is really just a slightly bigger version of the same plane.
The number one suggestion: Read the instructions, and study the pictures, multiple times before starting. Then read and study each step multiple times before cutting or gluing the parts.
I recommend building the "sport" wing versus the "trainer" wing, and using ailerons from the beginning. The trainer wing has so much dihedral (looks like a flying 'V') that it will blow over in the slightest cross-wind.
I built the bolt-on wing option rather than using rubber bands. This is just a personal preference. I've seen rubber bands destroy a wing in a crash. I crashed my PT-60 (the first time) and the bolts broke with very little damage to the wing.
In general, follow the instructions as closely as possible and you should end up with a good plane.
overbored77 05-28-2007 04:53 PM
1 Attachment(s)
I built my PT with the bolt on sport wing. and no washout. Make sure you build on a perfectly flat table and read the instuctions
a few times before starting. Very easy build and can be done in a resonably short amount of time. Remember to
take your time and dry fit all pieces and sand parts for proper fit.
Good luck and happy building.
acarter 05-28-2007 05:48 PM
i just got done with my first kit and i covered everything seperate, stab, fin fuse, wing, is it better to cover the plane after you glue the parts on or before?
overbored77 05-28-2007 06:32 PM
On my PT and my Tiger 60 I covered the Vertical and horizontal stabilizers after gluing them to the fuse.
I covered the ailerons elevator and rudder seperately then hinged them when the covering was done.
I think it is a matter of preference. Also some people don't like to cover 90 degree inside corners.
horace315 05-28-2007 07:14 PM
i would go with the sport wing and wing bolt option.this plane is a good first plane,my daughter and i built the 60 size.with the sport wing you can do some advanced manouvers after you learn on it.i cover everything first seperate then assemble and make fillet pices to cover the glue joints to me a plane looks better that way.
horace315 05-28-2007 07:22 PM
dan876 06-07-2007 12:24 PM
Tank you...
Alex7403 06-07-2007 12:47 PM
1 Attachment(s)
Hello Dan,
What a great mustang...
Alex
dan876 06-08-2007 03:30 AM
Hi alex, how are you. How was the flight back home? I resived the manual you sent me.
tahank you for the photo, I liked it.
Dan/
dan876 06-09-2007 12:24 PM
Finaly I opened the box. I couldn't start building because the room was full.
Now I have place and I already started.
dan876 06-23-2007 05:59 AM
I have a question: When I glue two parts togather, should I glu them from both sides or no? Because as I see now from one side they are glued and from the other side no.
Another question is: What I have to do if both of my Fin parts are not strait? I mean that both of them have some initial curvature.
Alex7403 06-23-2007 10:29 AM
Hello Dan,
how bad is the curvature?
about gluing, i attach the parts together on a straight board with pins, then i drop few drops of thin CA on them and let it hardened.
Alex
dan876 06-24-2007 02:05 AM
Thank you alex,
the curvature is not so bad, it's small.
Can you tell me what form of "V" sould I do on the elevator?
Alex, your plane looks very good.
Alex7403 06-24-2007 03:11 AM
what stage in the instructions?
thanks, im working on my plane :)
Alex
dan876 06-24-2007 10:42 AM
1 Attachment(s)
Hi Alex, I asked about the form of "V", but now I'm fine.
I finished the tail and started the fuse sides.
Tell me when your plane is finished.
Dan
farr301 10-11-2007 08:32 PM
I built the Pt-40 and maidened it just a few days ago...it has the A wing and flew great!!! I have yet to test it in a crosswind...........
Good luck with your build!!!
Farr301
