RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Wing Dowels (https://www.rcuniverse.com/forum/kit-building-121/6431127-wing-dowels.html)
jollyroger 09-30-2007 08:18 AM
Wing Dowels
My Sig Kougar kit uses 1/4" dowels for the wing mounting. I've read to substitute with 5/16" dowels instead. Is there really that much difference with a plane the size of a Kougar?
MinnFlyer 09-30-2007 10:34 AM
RE: Wing Dowels
Nahhhhhh.
The 1/4" dowels will be plenty
jaka 09-30-2007 11:25 AM
RE: Wing Dowels
Hi!
Sure! It will work. But a much better way is using aluminium arrow shafts for wing dowels. Never compresses like wood do and much stiffer and lighter.
dbacque 09-30-2007 11:50 AM
RE: Wing Dowels
Using larger dowels will help to prevent them from breaking in a crash. Instead of the dowels breaking, the wing will snap.
I'd prefer to replace dowels than build a new wing.
bayareajeff 10-01-2007 01:49 AM
RE: Wing Dowels
ORIGINAL: dbacque
Great point!
J
prgonzalez 10-01-2007 08:32 AM
RE: Wing Dowels
I am not sure if this applies. But, one time I saw one 30% Extra 300 come down in a vertical spiral because the dowels failed in one wing in middle air. The wing rotated 90-deg.
Any ideas what could have happened?
Pedro
MinnFlyer 10-01-2007 08:57 AM
RE: Wing Dowels
You're talking about a different type of dowel
Gringo Flyer 10-01-2007 02:01 PM
RE: Wing Dowels
I think it would be cool to see a 30% plane with dowels and rubber bands to hold the wing on:D
MinnFlyer 10-01-2007 02:46 PM
RE: Wing Dowels
1 Attachment(s)
I believe these are the dowels we're talking about
prgonzalez 10-01-2007 03:15 PM
RE: Wing Dowels
Ah, I see now. A picture worth a thousand words. The dowels I referred insert into the side of the fuselage to prevent the wing from twisting once is in the wing-tube.
a65l 10-01-2007 03:28 PM
RE: Wing Dowels
Anti-rotation dowels versus wing retention dowels.
A
submikester 10-01-2007 10:17 PM
RE: Wing Dowels
Yeah, I don't see a lot of need to make them bigger. Plus by making them bigger the wing leading edge may actually become weaker because of the larger holes required to hold them.
