Sukhoi .40 fuselage problem
1 Attachment(s)
Started my fuselage last night by taking the left and right sides and clamped and pin together( squared up the front and the wing area as best as I could get them) then I sanded every where the did not match up, not a lot of sanding to make the sides the same.The problem that I have is one side is out of square,center line is good . the area that is out is from the back of the wing to the tail, I check with the square every 2'' and it is all good. How can I correct this? I'm going try to add some pics Thanks PUB
RE: Sukhoi .40 fuselage problem
never mined the question, I think I have it figured out. pub
Read your thread. Who makes the kit ?Is it made by AK MODELS? if so i have one to build .Do you know eney one who has built one befor and flown it and how does it fly. what powerd it i have a ax 55 . I also fly 4500 ft and i need a little extra power .but a fx 46 would work fine .
Millsap< the kit I have is a Midwest , dated !992,I don't know anyone who has built this ,this is something that I wanted to for years and just started a couple of months ago. I thought that there were builders that could give me a answer or a direction as to what to do. So sorry I can not give you a answer at this time Thanks pub
PUB the photos on your thread look like the same build proces exactly maybe a copycat . My kit is about 2 years old bought it at a swap meet 50$ alot of light if light ply on fuse what is the final waight supos to be .My instructions dont tell me, Looks like it builds hevy .Had to go on line to get instruction manuel but it came with good plans and good hardware all gp stuff i think.I have not started it yet still working in a 25 size taylorcraft bulding a bush plane with floats kinda detailed doors and full detail in side. TALK TO YOU LATER
Millsap the flying weight is 5-5 1/2 lbs 2 cycle .35-.45 4 cycle .40-.50 wingspan 54'' wing area 521 sq.in. Tom Herr design. pub
pub mine has a wing span of 53.3 lenth 43.25 waight 5-1/2 wing area 520 . Sounds like metric conversion ,im going back on line to see where it is made .TALK TO YOU LATER.......
| All times are GMT -8. The time now is 04:43 PM. |
