RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   How much CA? (https://www.rcuniverse.com/forum/kit-building-121/6897228-how-much-ca.html)
drywaller 01-12-2008 08:43 PM
How much CA?
Hey all, I am building my Greatplanes Learjet kit (finally). I have used just under 2oz. of thin ca for One complete wing panel and the tail group. Is this far too much?
How much are you guys (and gals) using on average per kit.
Thanks for the help, Marco.
ps. dont forget to subtract what gets stuck between our fingers![sm=71_71.gif]
Dr1Driver 01-12-2008 09:40 PM
RE: How much CA?
Thin CA will typically soak in about 1/2" either side of the application spot. There is no need to create fillets in the joint seams.
Dr.1
rwright142 01-12-2008 09:44 PM
RE: How much CA?
I rarely use CA.
Most of my wood is held with Titebond (wood glue).
I use Epoxy for the firewall and landing gear mount (high stress areas) but most of the plane is held together with wood glue.
I use CA to strengthen threads I've tapped for nylon bolts and I use thin CA for CA hinges.
That's about it.
kbear 01-12-2008 10:10 PM
RE: How much CA?
You'll go through thin CA much faster than medium. It just flows so fast. I've used about 3 oz medium so far on my Hots build.
http://www.rcuniverse.com/forum/m_6707116/tm.htm
You'll have to judge for yourself the amount of work compared to your plane. You may have allot more to glue in comparison.
mmattockx 01-13-2008 12:52 AM
RE: How much CA?
ORIGINAL: kbear
Wow, that seems like a lot. I have the wing and ailerons all framed up on a 40 sized Mojo, built mostly with medium and thin CA. I have used about 1/3oz of medium and 1/2oz of thin. I have used some wood glue as well for gluing the center rib assembly together, but almost everything else was CA. A much better way to use the thin is with applicator tips (if you don't already use them), they make the flow much more controllable and precise.
Mark
kbear 01-13-2008 12:59 AM
RE: How much CA?
I've been pretty sloppy with the CA. I also forgot that my daughter has been out in the shop with me making things with the scraps. I will for sure look into the tips on my next build. I know I wasted allot because the tips let it flow to much. Live and learn.
SunDevilPilot 01-13-2008 10:14 AM
RE: How much CA?
1 Attachment(s)
I just use what I feel is appropriate. On my 1/5 Scale Cub Build I have gone almost entirely through a 4 oz bottle of Medium Super Jet. The build is almost done and everything has been glued twice. Once to tack it and one to really bond it together. I wouldn't fear extra weight, there is just not that much glue there.
A sample of my project.....
SunDevilPilot
DavidAgar 01-13-2008 10:33 AM
RE: How much CA?
You may want to switch to a medium CA. Thin CA should really only be used on wood joints that have no gap on them. A medium CA will help in filling those gaps. A medium or thick CA will also give you a few seconds of adjustment time if your parts need to be adjusted, where as thin CA is instant. Good Luck, Dave
drywaller 01-13-2008 11:02 AM
RE: How much CA?
I think that thin ca is the best choice (for me) for wing ribs and the like. The instant set of thin ca on the light balsa to balsa assemblies makes for a short process. I talked with a friend that has built many models over the years and was told that Two to Three 2oz. bottles is normal on an average size kit. What he stressed was ""use what it takes to make a good glue joint"
It is my understanding that much of the glue weight evaporates upon curing.
Besides more weight="bigger engine and go faster to keep it in the air"
Marco.
Warbird Joe 01-13-2008 11:56 AM
RE: How much CA?
ORIGINAL: rwright142
I rarely use CA.
That's about it.
I agree with RWRIGHT142.... I am using nothing but Titebond and epoxy on the firewall and landing gear and CA on the hinges. yeah it may ake longer for the glue to dry but it really soaks in and cures nicely. And it is a lot easier to sand than CA
gfdengine204 01-13-2008 02:25 PM
RE: How much CA?
All this talk about Titebond prompts me to ask, How do you apply it? I am working on my first balsa stick build, using thin and medium CA, where I pin my pieces and then squeeze the CA on the joints after the pieces are set.
Thanks!
Warbird Joe 01-13-2008 02:37 PM
RE: How much CA?
ORIGINAL: gfdengine204
Thanks!
for instance the wing ribs. just squirt it on the brace where the groove in the rib is and then the bottom edge and put on the wing. It is great. and you don't have to worry about ventilating
jrcaster 01-13-2008 02:48 PM
RE: How much CA?
1 Attachment(s)
2 ounces of thin CA for 1 wing panel is too much. Use the thin to tack the parts together, and go back and use medium to fillet the joint. Using CA and epoxy only to build a model, you should only use about 1 to 2 ounces of thin, and maybe 2 ounces of medium for the whole model.
I agree that the tips on the CA bottles are way too big. to be able to use less try some of these. They pay for themselves with the amount of glues you save on the first bottle.
I use the tips on thin and medium CA, the pipettes I haven't found use for yet, and the Monoject syringe I use for wood glue. The T-pin keeps the wood glue from setting up.
Warbird Joe 01-13-2008 04:43 PM
RE: How much CA?
ORIGINAL: jrcaster
JRCASTER. I can see where you would need to worry about weight with an indoor electric plane but not a nitro plane. worse case scenario you add a lb. to the plane with glue. Then again is that my lack of experience guessing this or what. I totally see how weight means the world with the electrics.
Acs_guitars 01-13-2008 05:01 PM
RE: How much CA?
To add a whole pound is a bit high of an esimate.... using 6 fl-oz of CA on a plane would only yeild 1 1/2 to 2 oz of weight. When the CA cooks off much of its weight evaporates. Anything that needs that much glue is large enough that the weight gain is negligible in the finished airframe.
I 100% agree with using whatever it takes to make a good joint. The major thing is making tight fitting joints and you will use less glue; no matter what type. I use thin on tight joints and only go back with medium and accellerator if it needs a structural fillet... I use thick only when I need the added working time.
kbear 01-13-2008 08:26 PM
RE: How much CA?
Do you guys use the accelerator just to speed things up, or are there other reasons?
jrcaster 01-14-2008 02:44 AM
RE: How much CA?
From what I understand, when CA cooks off it does not lose weight. CA is not a water based glue, and it does not work by evaporation. with 2oz CA in one wing panel alone, that is 4oz for the wings, and another 2 to 4oz for the fuselage. Not only is the weight racking up, but also the expense at 3 to 4 dollars an ounce. That would also mean even on a glow plane that you would have to go with the largest engine just to get off the ground. If weight wasn't such an issue even with glow/gasoline models, they would be designed with pine, oak and other woods that are much cheaper to obtain and sturdier than balsa and lite-ply,
Accelerator is used to speed up the curing process of CA. a side affect is that it gets harder, and boils up leaving a nasty looking mess. The only time I usually use accelerator is when joining balsa to plywood, or to plastics. Thin CA alone when joining to plywood can take a few minutes. Also if you get medium or thick CA on your skin, don't use accelerator. It will get hot enough to blister.
GRANT ED 01-14-2008 07:06 PM
RE: How much CA?
Personally I use wood glue for most joints and CA only when I want the speed. Just remember that excess CA will make the wood britttle and hard to sand so only use what you need to.
