RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Piper Cub (https://www.rcuniverse.com/forum/kit-building-121/7303765-piper-cub.html)
USA_1_INK 03-29-2008 10:44 PM
Piper Cub
Hey Guys I help Help . I bought a Sig Piper Cub J-3 Kit at a small Model Expo . What I didn't realize , it didn't have the illistrated assembly manual in the box . Till I got Home .
Is there somewhere I can download it from , I have looked on Sig's site , didnt see anything there . Or if someone has the manual they dont need anymore . Anything would be helpfull . this is my second plane building . So , I dont think I could fumble thru . without getting ahead of my self .
Thanks USA_1_INK
Live Wire 03-29-2008 11:23 PM
RE: Piper Cub
Which Kit did you get, I mean the size will help;)
USA_1_INK 03-29-2008 11:34 PM
RE: Piper Cub
not sure of the scale , It has a 71" wingspan , the box says to use a .19 to .35 engine .
Live Wire 03-29-2008 11:46 PM
RE: Piper Cub
USA
That is one of the older SIG kits, You may be able to get the plan a AMA plan service. Mine are all the later planes. Some one may have a set of plans that will chime in and let you no.;)
USA_1_INK 03-29-2008 11:53 PM
RE: Piper Cub
Thanks for the Info , And your Help . I will look into the AMA Plans Service .
Thanks again
papermache 03-30-2008 09:13 AM
RE: Piper Cub
Ink,
Try calling SIG. They would probably be able to set you up with a manual for a nominal cost.
papermache
RCVFR 03-30-2008 05:12 PM
RE: Piper Cub
This is an excellent kit, however it requires some experience to build. It is an older design, and if you have not previously built at least a couple of kits, put this one aside for a future project. Modern kits have laser cut, computer designed components with highly detailed instructions. Do a couple of those first, then tackle the SIG 1/6th Cub. ;)
USA_1_INK 03-30-2008 08:07 PM
RE: Piper Cub
1 Attachment(s)
It's not the first kit I have build , its the second Sig tho . I'm not a stranger to building , I built and race R/C Boats for 12 yrs . So I have a little expereince in construction . The first plane kit I built was a Sig Kadet Senior. everything turned out great . fly like a dream .
Live Wire 03-30-2008 08:58 PM
RE: Piper Cub
USA
I it is the one I am thinking about it builds like the Senior. A lot of sticks;)
SDM 04-01-2008 10:22 AM
RE: Piper Cub
If you built a Cadet Senior you will be fine with the Sig Cub. Building is pretty much the same as the Cadet with a few other techniques thrown in to advance your skills but nothing that can't be done. A good kit but it takes alot more assembly than other kits. Sig should be able to supply you with a manual. I would offer a copy of mine but it is buried in storage..:eek:
Sam
Andrewmc 04-07-2008 08:12 AM
RE: Piper Cub
Would it infringe too many copyright laws if I offered to scan and email a pdf version of the manual to you?
Mine is currently at the covering stage, taking a pause while I finish off a four star 40.
The piper cub is a very satisfying build. Send me a PM if you would like the manual electronically.
SBOT 04-10-2008 07:22 PM
RE: Piper Cub
If you still need that manual. I have one I will send you. Let me know.
Oscar
USA_1_INK 04-10-2008 10:48 PM
RE: Piper Cub
Thanks for all the help . AndrewMC Sent me a PDF. File for the Manual . It will be a great help .
Thanks for all who helped out .:D
KARL USA_1_INK
