Boosted Y Harness ?
Building a 40 size plane and installing servos in wing for each aileron. Using standard JR servos and 4.8 volt pack. Y harness will plug into servos with no extensions. This is not a 3d plane so ailerons are not large. Do i need a Y harness with a booster or will the standard Y harness work?
Thanks Steve |
Boosted Y Harness ?
Just the Y harness will will work fine.I have many planes with that setup with no problems.
Depends on Radio
It depends on what radio you are using. If you are using the older Z-PCM then you need a buffered Y-connector. If you are using the newer S-PCM then a standard Y-connector is okay. If you are using standard FM then a standard Y-connector is fine.
| All times are GMT -8. The time now is 07:52 AM. |
