RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Ideas needed for feather tail feathers (https://www.rcuniverse.com/forum/kit-building-121/8332694-ideas-needed-feather-tail-feathers.html)
KitBuilder 01-07-2009 11:06 PM
1 Attachment(s)
I'm building a kit from the 80's - Craftair Firebird. The rudder and elevators are constant thickness balsa. Rudder is 1/4" and elevators (2) are 3/16". They need to be turned into "wedges" with a thickness of approx 1/8" at the trailing edge for rudder and 1/16" for elevator TE.
The top is where it would be beveled for hinging. What is the best way to get an equal angle on each side?
qldviking 01-07-2009 11:25 PM
RE: Ideas needed for feather tail feathers
I find it easier in that situation to just bevel on the one side, I use my sanding bars only, I have coarse and fine. I just mark what the final thickness will be and carefully sand down. takes me about 5 min to do a 30 inch aileron.
KitBuilder 01-08-2009 12:03 AM
Doh !!... good point... I can just bevel the one side... then center it up on how I do the V bevel on on the front / hinge side.
Thanks..
qldviking 01-08-2009 12:22 AM
one usefull item I made for the job, is a piece of 3/16 ply 12" x 36" where I cut out a 1" x 34" section out to hold the strip I am shaping, I clamp that to the bench so the strip I am shaping is hanging free of the bench giving room to sand etc, and you only have to hold it on the bench. makes it a lot easier
Ram Jet 01-08-2009 12:51 AM
If you have access to a belt sander mount the sander upside down in a vice or device of your choosing, draw a center line down your trailing edge and sharpen it like they manufacture knife blades.
Bill
Peter_J_Weller 01-08-2009 07:23 AM
ORIGINAL: Ram Jet
Bill
Sounds safe, I use a 12" radial Drum Sander with a larger piece of hardwood that is notched out to hold balsa stock in. Takes some time to make the jig, however once that is done it has been good for many airplanes.
MinnFlyer 01-08-2009 08:27 AM
1 Attachment(s)
Here is the best way I have found to mark where to sand.
This example is for a hinge bevel, but it applies to sanding the TE also:
http://www.rcuniverse.com/forum/fb.asp?m=8110718
And here is an example of using this method on a TE:
