RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   need to build (https://www.rcuniverse.com/forum/kit-building-121/838419-need-build.html)
sjim 06-06-2003 01:50 PM
need to build
i need to build ailerons for a senior kadet, the wing is already built :mad: but not covered. can anyone help me,or show me with a diagram, or i`am be on help. thanks Jim :)
MinnFlyer 06-06-2003 02:32 PM
need to build
I am not familliar with the construction of the trailing edge of a senior kadet, but if you can describe it for me, I'll be happy to draw something up for you.
Is the TE a piece of tapered stock? If so, how wide is it?
Give me a good description, and I'll give you a good solution.
sjim 06-06-2003 03:30 PM
need to build
thanks for the help, the stock is tapered and 1 and 1/2" wide, leading edge 1/2" thick and trailing edge is1/8" thick. about 36" wide ea. side, that`s from center of wing to end, at trailing edge :D ps: i can email you a picture if needed. thank again Mike B Minn Flyer
CAPtain232 06-06-2003 04:03 PM
need to build
1 Attachment(s)
As mike mentioned, you need to describe the construction of the wing.
Guessing that it is basic rib construction, I would suggest you start by deciding how long you want the aileron to be. Then decide where you want it located (at the end, in the middle or wherever) Then when you have this all figured out, if the wing already has a solid trailing edge from root to tip, you will need to cut the decided area out. When you cut this area out, you need to make sure that there is enough wood to put hinges into. If there is not, I would cut out another 3/8" into the wing and then glue in a piece of 3/8 balsa stock the entire spane of the aileron. Cap off the ends of the section you have cut out and you should be ready for the aileron installation.
Here is a picture of a HERR STAR CRUISER wing that I put ailerons on. This kit is designed without, but I did exactly what I described above. You can see that it is a fairly small aileron and for this reason, I moved it toward the outside edge, but not all the way. The only reason I put the ailerons on this plane was to have better control for landings.
CAPtain232 06-06-2003 04:07 PM
need to build
1 Attachment(s)
here is the bottom side showing the control linkage set up
One servo to control both ailerons. Linkage from the servo to the aileron is nyrod that has been routed through the inside of the wing and exits just before the aileron
MinnFlyer 06-06-2003 04:19 PM
need to build
1 Attachment(s)
We're both on the same track Jeff.
Here's a picture. I would add balsa strips to the front of the trailing edge in between each rib. In the pic I put 1/4" x 1/4", but if you can fit 5/16, or 3/8" better yet. Be sure to get a good bond to the ribs.
Then cut off the Trailing edge leaving about 1/8" of the original tapered stock. Bevel the LE of the aileron, and add hinges.
sjim 06-06-2003 07:27 PM
need to build
:D :) thanks Minn Flyer and CAPtain232 you both have been an invaluable source of information, i think i can do it, when it done i`ll let you know and maybe even put a picture up,( if i can figure out to do that) :) thanks again. sjim
MinnFlyer 06-06-2003 07:38 PM
need to build
Cool, we'd love to see it!
CAPtain232 06-06-2003 09:47 PM
need to build
If you need any help as you go, just email me
[email protected]
derailed 07-07-2003 02:07 AM
need to build
1 Attachment(s)
i found it easy to convert my wings to aileron equiped
here's my piper cherokee wing i converted in only 20 minuites
sjim 07-07-2003 02:10 PM
need to build
thanks derailed, looks good, i did exactly the same thing. are you using two servo`s or one. if one how did you route you linkage ?
sjim
derailed 07-07-2003 07:44 PM
need to build
i used two servos
this way, it can double as flaps
AKA flaperons
wonder how it stalls
lol
sjim 07-08-2003 03:38 AM
need to build
ok i never thought about that, flaperons, i like going slow, but not that slow :D guess i`ll use the two servos system also,thanks for info, cul sjim
derailed 07-08-2003 12:17 PM
need to build
thats what we're here for isn't it?
to help each other
lol
i got to get my claws on another herr cherokee
the next one, i want to add these flaperons and add retracts to it
it is a nice plane and fun to experiment with
hmmmm
what other changes could i do to it?
oh well
i gotta find another one first
lol
GeraldO 07-08-2003 08:20 PM
need to build
1 Attachment(s)
On my Senior Kadet I just cut off the back of the stock trailing edge which left 5/8" remaining. The thickness was then about 1/4" at the back edge. Next I used standard 1/4"x2" tapered stock to make full width ailerons. CA type easy hinges were used and dual servos. The tip of the aileron stock gets angled to match the wingtip shape.
This is about the easiest way to make ailerons for this wing. By the way, I've been flying this plane for about 2 years now and it still remains one of my favorites.
GeraldO 07-08-2003 08:29 PM
need to build
1 Attachment(s)
Here's a closeup of the servo mounting area. It just takes a few extra sticks and no structural changes to the wing.
xtech 07-09-2003 12:35 AM
Added Ailerons to 3 channel kit
I had a old sig Kadet JR that I added ailerons to. Not as bad as thought. Got aileron kit at Tower Hobbies. Cut hole in bottom w/dremmel wheel. epoxy in some servo rails. Cut off trailing edge. Put hardwood strip in back then hinged to aileron stock. Works great. Good luck. See my member picks.
sjim 07-09-2003 01:27 AM
need to build
yes sir derailed, and i always need help :confused: :D . i like the looks of the herr cherokee, sharp plane ,are they hard to find. i think i`am gonig to build the thunderbug as my next project, :D but i hear the plans are not so good, and you might as well throw them away. :eek:
thanks for pictures and info GeraldO. excellent pictures :cool: , by the way. i was going to use the T E that i cut off for the aileron, which is about an inch and three-eights wide, i reinforced between each rib with half inch by one quarter inch stock, then made cut at very end of the ribs, do you think 1+3/8" is enought aileron for that wing. or should i use 2" stock.
how about a picture of the whole plane
derailed 07-09-2003 01:35 AM
need to build
the herr cherokee is an easy find
still available
not too expensive too
so for me, that spells flying labratory
hmmm
now besides ailerons, what else could i try?
retracts,lighting....................
GeraldO 07-09-2003 02:27 AM
need to build
1 Attachment(s)
I think the 2" ailerons are just right. I couldn't tell you if 1-3/8" will be too small, but I can tell you that I fly mine with maximum aileron deflections. I also had reduced the dihedral by 50%.
Here's a picture of me standing behind the Senior. This was taken last month at SEFF (Southeast Electric Flight Festival). The Senior is electric powered as are all my other planes in the photo.
A link to my web page on my Senior Kadet. http://bellsouthpwp.net/g/e/geraldod/senior.html
Off topic, my Herr Cherokee page: http://bellsouthpwp.net/g/e/geraldod/cherokee.html
sjim 07-09-2003 02:39 PM
need to build
Grate looking Senior, all of the planes in fact. The plans called for 6" dihedral, i went with 2" dihedral, 1" each side, i`am anxious to see how it handles. thanks for everone`s help and input.
