RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   1/4 scale cowl for OS-160ft (https://www.rcuniverse.com/forum/kit-building-121/8420051-1-4-scale-cowl-os-160ft.html)
carl01 01-30-2009 03:29 PM
1 Attachment(s)
HI Guys, Im having some problems with my cowl ,i bought a fiberglass one and had to split it down each side to get it around the cyl's . It' looks ok but im trying to figure out how to secure it ? Any ideas
w8ye 01-30-2009 06:58 PM
RE: 1/4 scale cowl for OS-160ft
I cannot see your split but the original was split top half and bottom half at the cylinders
LesUyeda 01-31-2009 10:14 AM
1 Attachment(s)
If you look closely, the screw just behind the valve cover is holding a plate of aluminum. Another screw goes into the bottom hole. This is used at 4 places around the cowl. If you wanted to get fancy, you could use a flat head screw for the one that will not be removed, and cover it over with spot putty.
Les
didn't take the photo the first time around. I will try again.
