RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   PT-20, OS FS .30 tail dragger? (https://www.rcuniverse.com/forum/kit-building-121/8595318-pt-20-os-fs-30-tail-dragger.html)
GaryHarris 03-19-2009 06:19 PM
I'm building sort of a second plane. Built many planes, flew few. I first learned to fly on the PT-20 about 15 years ago and want to hotrod this one after re-learning with my new trainer. (Hobbico Superstar) Can anyone tell me how to build the PT-20 as a tail dragger?
Thanks.
phread59 03-19-2009 06:48 PM
RE: PT-20, OS FS .30 tail dragger?
I have not built the 20 size. I did build the 40 size 1ST generation kit. So take this with a grain of salt. I would move the landing gear block forward untill the wheel axles are even with the leading edge of the wing. Add a small piece of light ply at the tail for a tail wheel bracket. Add a Dubro or Sullivan tailwheel bracket and wheel. Anchor the top of the wire on the bracket into the rudder and you should be set to go. I did this to a Tiger 2. Worked like a charm. Good luck with the bash. Should make a great flying plane.
Mark Shuman
w8ye 03-19-2009 09:27 PM
Mark's words are correct.
I've done a couple of tricycle gear planes this way. I used aluminum gear and put a plywood block behind F-2 to hold the gear retaining screws. I did the tail wheel as described. Flew great.
http://image2-6.rcuniverse.com/e1/ga.../lg-144499.jpg
GaryHarris 03-20-2009 04:34 PM
Thanks guys.
shd3920 03-20-2009 06:36 PM
GaryHarris, I have built two PT-40s. One as a taildragger with rear-mounted servos and the other the traditional tricycle gear. I am currently helping someone by email building his with great success. If you would like help in building yours feel free to email me and I will help you all I can. [email protected]
GaryHarris 03-22-2009 06:48 PM
Thanks. But I just took all those warped pieces of sticks and stomped the crap out of them including the ones missing if I had them. I'm so angy at Great Planes I E Mailed them with my dissapointment with this kit. Get this. 5 main spars and only one trailing edge. And the spars look like horse shoes. [sm=angry.gif]
shd3920 03-22-2009 06:58 PM
ORIGINAL: GaryHarris
Instead of destroying the kit, it would have made more sense to return the kit for a replacement. Nice to know you have the money to throw away.
GaryHarris 03-22-2009 07:34 PM
ORIGINAL: shd3920
I was sorta joking bro.
GaryHarris 03-23-2009 06:39 AM
Man I was upset last night. lol. Guess I expected the same quality as the LT-40 I built. I think Ill just get the LT-25 and be done with it.
