Greasing
ON, CANADA
Hi I have a new Cali 30.
Im wondering what I should be greasing on it?
The manual says you need grease but I cant see anywhere to grease by following the instructions.
Thanks.
Thanks.
Alright, YOU SHould grease the SWASH PLATE, the ball bearings in it and most of the other's you see. You should grease the axle and bearing on the tail rotor. You should greae the hole where you put the starter in (trust me on that one) and you should grese a few gears here and there that i can't name on the top of my head/ HOPE THIS HELPS
