How to install the Upgrade One Way bering on my Caliber 30
After a suspect OWB failure I bought the Upgrade one from my LHs. Now how in the heck does it go into the drive pully. Which way goes in. A rough diagram would really help guys ..
thanks
thanks
My Feedback: (23)
RE: How to install the Upgrade One Way bering on my Caliber 30
Yea, take the C clip off the top of the tail belt gear, then take the lock screw on the bottom metal gear, and the shaft will slide staight up. the one way bearing is in the big gear. One side of the bearing is marked for direction. Pay attention to which way it comes out so you can get the other one in the same way. Hope this helps.
thanks for the reply. The problem is that the upgrade bearing is different thant the stock one. From What I have figured out it goes in the other way ( based on the arrow pics) from the stock bearing. OH yeah and I made the mistake of tapping the whole assembly on my hand and the bearing popped out BEFORE I had a chance to see which way it was seated [:@]
