New series2 rotor blades. What needs adjusting?
ME
I ordered a new set of series 2 blades for my 110 and the tech guy from LM said I'll need to use (2) #4 grips (which I have), but I'll also have to adjust the swashplate pushrods or something like that. Can someone clarify? Can I just slap on the new blades, check the tracking and be done withi it?
RE: New series2 rotor blades. What needs adjusting?
What grips were you using with the old style blades? If it was 2 six degree grips you should be able to run 2 fours without any need for adjusting. If you were running a four and a six degree grip (5 degrees) you will have to re-track the blades if you drop to 2 four degree grips. Other than dropping your pitch 1 degree I don't think there's anything you have to do. I hope this helps.
Mark
Mark
