LMH Helicopter Discussion of all LMH helicopters both electric and glow.
Need Help.
Old 10-09-2004 | 10:45 PM
Default Need Help.
Hi i got my corona a couple of day ago and started building it today.Im almost done.I have the belt drive up grade but the tail rotor will not spin?Any suggestions on what might be wrong would be helpfulo.THANKS
Jared
Old 10-10-2004 | 12:39 AM
Default RE: Need Help.
make sure you have tightened every setscrew. The pulley on the main shaft is most likely slipping, if the insert was not aligned correctly. What I use, is a standard cap screw or tap to chase it before mounting it on the main shaft. it does not need to be super tightened, just snug after you get everything turning, you do need to make sure that everything is turning in correct direction. when the main rotor turns counterclockwise, the TR need to turn clockwise.
Old 10-10-2004 | 09:55 AM
well upon further inspection i saw that the spacer was off by about 1/2mm./I was in the setscrew hole.So i tape out the spacer turned it made sure it was correct.Tapped it back in but it all back together and there you have it propblem solved.Askman thanks for your idea of what might of been wrong YOU WERE RIGHT!!!.Thanks sop much im very happy now.
Jared
Old 10-10-2004 | 09:58 AM
im on my dads comp thats y the name is differnt sry for any confusion.
