.15 engine conversion and still have same problem as the V6 READ!
CA
hi, when i first got my lmh 110 it has a v6 it fly pretty good for like 1min then the engine heats up and wont lift the helicopter off the ground! i did everything adjusting the needle vavle and the needle next to it. after all that nothing so i finnaly decided to do a .15 pullstart engine conversion on it. it starts up fine engine is strong lift helicopter like nothing but it stilll has the same problom as the stupid v6 it wont lift when its hot! anyone know why?
RE: .15 engine conversion and still have same problem as the V6 READ!
well, my guess is that your engine is overheating. when it overheat, it doesn't fire at right time(kinda likecar engine start to ping) and lose power, this may be due to your gearing is wrong. most of .15 motors (car one) are high rpm low torque motor. this could cause overheating.
CA
nvm i just flew it this morning, nothing was wrong with it, no heat problem. flew it for about 10-15 minutes. weird is it because of cold day? im thinking of saling it and get a electric helicopter or convert it to electric, im sick and tired of gas !
btw can anyone give me a list whats needed to convert to electric?
AE, GERMANY
Running too lean, fuel with improper oil content, pitch too low, etc.
We need details!
We need details!
ORIGINAL: crx_ef8
New chassis cut out to suit electric motor.
Mega 16/15/3 9T pinion
CC Phoenix35 ESC
8cell KAN1050 or 3s1p 2450 Tanic Lipoly.
