Corona 120?
TX
Corona 120?
Are there any Corona 120 (electric) flyers out there? if so,,i just got my kit yesterday,,brushless motor and ESC,,and would like any suggestions to help my first setup for chopers cause its been a long , long time,,since i have flown rotorwings,,thanks,jim
RE: Corona 120?
jim, there is an LMH forum on rc universe for all the corona stuff. I have three electric helis and let me assure you, the LMH120 is the most durable heli out there. I am running brushless as well. recommend you start out with the 4 degree blade grips until you get used to the way the bird handles. I also converted the tail drive to a belt drive as well as a belt drive for the brushless motor.
RE: Corona 120?
Hey Jim, congrats. It is a fine helo. What crutch type? Alum or wood? What motor and esc? I'm running a stock (wood crutch) 120 with a Mega 16/15/3 and Eflite 40 esc. The only mod I'm using is the Hyperdrive kit (belt drive from www.ballistictechnology.com ) replacing the main gear. I'm using 3-cell Lipos (2100s) and getting 12 minute flighttimes.
good luck
Chris
good luck
Chris
CT
RE: Corona 120?
Congrats on your new purchase. If you follow the instructions in the manual, you should have no problem getin er up in no time. Most
of the crashes are money free, but the ones that cost are not much. Plenty of upgrades are there for the taking, but have fun with it. If you have any questions, I am sure there are plenty of people willing to help.
Brushless is the way to go, but does not need to be right away. I went there because I had alot of problems with the fusion 7 and controller.
good luck
Jer
good luck
Jer
CA
RE: Corona 120?
ORIGINAL: Airborne82nd
good luck
Chris
good luck
Chris
Just curious because I have some and was thinking about changing the motor to a brushless motor (Mega 16/15/3) with a Castle Creations 35 or 45.
TX
RE: Corona 120?
finally got the gyro set correctly and the little rascal actually flew (little),,beeen a looog time since i looked into the blades ,,fun and only broke the fin on the boom (plastic) made one out of aluminum and will see if it will hold up to my learning curve,,,getting 12 minutes out of my 6 cell nicads (twin force got robged),,,may go to the 7 cells tho,,Liteflite reccomends them ,,,later,,jim
My Feedback: (8)
RE: Corona 120?
I just found out the Coronas are backordered at HeliHobby, any suggestions on where I can get one
Brian Marks
[email protected]
Brian Marks
[email protected]
RE: Corona 120?
I was at the Roffee store a couple of weeks ago and they had about 7 of them in boxes. Great people to work with. The website is not that great but if you call and talk to Mike, he will set you up.
www.roffeetvhobby.com
Good luck
Chris
Good luck
Chris
VA
RE: Corona 120?
Not anymore, he is out also. Looks like most vendors are out at the present time. They are saying that they are suppose to be shipped out of the factory in a day or so. I am waiting on one myself.
Good luck
Chris
Good luck
Chris
CT
RE: Corona 120?
You could also try here. They have them in stock. http://www.shopatron.com/index/113.0.385.246.0.0.0
Jer
Jer
TX
RE: Corona 120?
Thanks for all the comments ,,,it does really fly and (heh, heh) its one tough bird,,straightened the boom twice, and one fin replaced,,still flying nicely on the original blades,,,damn, if i cant hurt it you must really have to dive into the ground from up very high,,,love this chopper,,it is more fun than i have ever had,,,in RC that is,,,been trying since i got out of the USN in 1965,,if you are looking into the electric choopers ,,better give this Corona 120 a look,,cant see how you can improve on the design or the durabiltiy,,,again,,thanks to all,,,jim
RE: Corona 120?
I'm assuming that 3-cell lipo 2100s that you are using is ThunderPower Gen2 ?
RE: Corona 120?
you can improve it alright, by getting nice upgrade for it. 16/15/3 is 3000kv motor best used with 8 cell. it works fine with 3S pack. you can use 16/15/4, but be prepared to run 12 tooth pinion....
ON, CANADA
RE: Corona 120?
Hi guys
I have a bare bones Corona kit, and am looking to put in a good brushless setup. The Hacker seems to be the best, however the price is prohibitive and don't think it's worth the investment. The other 2 choices I am aware of is the Astro and Mega setups. Can anyone point me in the right direction in this regard. I intend to go with running lipo batteries.
I am an experienced pilot, however am new to electrics.
Thanking you in advance
Steve
Steve
CA
RE: Corona 120?
Most will go with the 16/15/3. If you check around I think some will use the 16/15/4 but a larger pinion. The old Astro 20's use to throw magnetics all the time, I'm not sure if they fixed that problem. Good luck.
RE: Corona 120?
i just bought a used 120. is this a fair deal? 1----. used great shape corona 120-----2.----new multiplex-BL-480-4D brushless motor 3.----new castle creations 45 amp speed control 4----.Crazy Crutch carbon fiber frame upgrade 5-----.carbon fiber feathering pate 6.----ikarus profi. gyro w\ heading lock 7.----3 hi tec hs81 servo s--- medal 8.----4 channel GWS transmitter w\cyrstals9.----------plus a box of blades 4 sets fins tail booms etc---------all for 350.00 did i get a fair deal?????????????
