Blade Tracking
GA
Is the blade tracking on the Corona as straight forward as the manual makes it out to be? I've tried going up and down with the mixing arms and can't seem to get it right. Which arm adjusts which blade?
Kip
Kip
Ok, start with marking one of the blades with tape at the end (tracking tape or any other bright colored tape will work) set the heli away from you, run the engine until it looks like it's ready to lift off, now you should be able to see which blade is lower or higher, now let's say the blade with the with the tape on it was too low, shut down the heli, set it in front of you, and turn the rotor head so that the marked blade (which was lower) is on your left side, now the link right in front of you is the one you want to adjust, to make the blade track higher turn the link out (make it longer) you could also make the opposite one shorter to bring the other blade down. I hope this helps
Good luck and be safe not to hurt yourself, First time I've learned how hard my LMH bites was when I was trying to track the blades, but that's whole another story
GA
Thanks for the advice. I moved just one link and that was the key. The manual calls for adjusting one and reversing the action on the other side to balance the input. I think that I was countering my own inputs. In any event, they are tracked and all is smooth. First flight tomorrow maybe.
Kip
Kip
