Throttle Linkage Problem?
Has anyone had any radio interference problems with the "metal to metal" conection between the throttle pushrod and the engine's throttle valve?
I'm almost ready to begin engine-run tests and this area looks like it could be a problem. I'm considering soldering a cable from the brass valve to the pushrod - but is it necessary? Any advice?
Tony
Tony
Thanks for your response Charlie. Good to hear you've had no problems in this area. But the metal to metal connection just looks like a problem waiting to happen so I'm definitely going to use Tink's idea (it's the easiest so far)
Tony
Tony
I drilled-out the hole in the throttle valve, fitted a length of shrink tube to the pushrod - Job Done
Just a little more "tweaking" and my LMH will be ready for some test flights
Thanks for your help
Tony
Tony
