Help!!!!!!!!
just tried to fire up the old vmaxx and nothing happened. (i did all u told me to to flush out the engine rog) but nothing worked it would run with the starter then when i took the starter down it stopped. Whats wrong here?
did you check the glow plug while you had it out? it should glow a bright orange to white when you put the glow driver/starter on it...,put finger over carb and bump it with the starter to draw fuel into the carb then try and start it ... Do you have a manual?
close needle valve and open it back up 2 turns and try it again set throttle at about 1/3 to 1/2 open when you try it...Rog
*Get a new glow plug
*make sure ur getting fuel into the engine
*Make sure ur Starter is fast enough
*cover the engine carb for a few seconds when starting
*make sure you have the right voltage on ur glow plug
*Get an eletric heli
