lst2 transmission
lst2 transmission
my lst2 will only drive if the throttle is on full but it goes real slow. i check the clutch,tuned the motor, and i checked the gear. i dont see anything wrong :,(
RE: lst2 transmission
Aha!! Check your grub screws in the middle driveshafts.. They are a usual suspect. They need to be threadlocked. This minor issue has caused lots of panic over the years, but can be solved very easily with a little drop of blue threadlock.. Check all four.. (one in front of rear diff, one on each side of the transmission, one in front of front diff...)
they all seemed to be tight...the slipper clutch wont tighten anymore. the rear wont tighten either. it turns but it wont tighten
Slipper nut was a good call.. Should normally be all the way in, then for me anyway 3/4 of a turn out..
Check the grub screws? Also, turn on the radio and receiver, but not the engine, and push the truck back and forth on the ground.. - including holding the rear wheels up off the ground, then the front, apply gas, break, let it roll in neutral, etc.. Everything free?
okay. i just tried to run it again and when i lift it off the ground the wheels turn a little but when i let off they stop dead...brakes?
ON, CANADA
Check your brake linkages? I have mine so that under full throttle, there is no brakes applied, but as the throttle linkages return to neutral some brake is applied, A drag brake of the sorts. Does your engine get up to full revvs?
i think i know the problem. i think its the clutch. im going to the hobby shop in the next few days to get it changed. i have more clutches but i need that tool to get it :/ oh well...at least it will get fixed. hopefully some bashing vids coming soon
ORIGINAL: bigben3576
no because the pistin still moves. i have a mach 427 motor. i need the plug thing
I use 1.1mm springs on the SH .28p6, and 1.0mm springs on the Mach 427.
The "plug thing" I think you're referring to is called a piston stop but I would never use one on a model engine. The risk of marring the glow plug threads and possibly punching a hole in the piston steers me away from using something like that.
Just my 2-cents.
i found the problem. it was the locking nut for the flywheel. the threads were gone. got it orderd and should be running by next week
ORIGINAL: Muskokarc
The clutch shoe tool is only around $9 on amain.com worth the small investment.
ON, CANADA
I got mine when I got a bunch of parts so shipping was not a issue that and looking back it was less than $9. Now I just need to get new shoes and bell for my rebuild to get it moving.
ORIGINAL: Muskokarc
