O'Donnell plugs for the Mach .26?
I just picked up some Odonnell plugs for my Mach .26 and was wondering if any one else has tried them.
They are made by Dynamite and are rated as Medium/Cold heat range for .21-.26 engines. They sound like a perfect match, but I haven't tried them yet.
I have been running O.S. LC3's in my Mach 26, and the engine has been running great. It just keeps getting faster and always runs in the low 200's. I realize that it is a hot plug designed for the Tmaxx, but my LHS has been back-ordered on MC 8's for a long time now. I can blow away a 2.5 Tmaxx even when it has a head start.
I realize that the heat range of a plug determines the timing of the combustion, but what is the real advantage of running a cooler plug in a big block engine? Is it better for the engine to have a slower combustion timing? Right now I don't see how this engine could run any better than it is, but I will try cooler plugs just because people recommed that you should.
So has any one tried this plug? And why should I use a cooler plug in a big block?
YT, BOTSWANA
RE: O'Donnell plugs for the Mach .26?
Which o'donnell plug are you referring to? The odonnell 99? Or the new Monster Truck plug. I read in one of these mags here that odonnell has a new plug for monster trucks with larger motors now. Your HOT OS plug should be fine in that Mach .26. I believe the manual recommends the HOT MC59 plug. Colder plugs are usually used for the hotter weather, and higher nitro content.
Matt
Matt
On the plug there is a number "99" engraved on it, so I'd guess that would be the one.
The package says
"O'Donnell 1/8 racing glow plug .21-.26........Medium/Cold heat range.........Dynamite". That's it.
Why is that? Does the higher nitro content have a lower flashpoint which would result in pre-detonation when using a hot plug?
What about the weather? How does that affect the heat range of the plug?
I've read where many people recommend cooler plugs for big blocks all the time, that hot plugs are hard on big blocks. Is that true?
The package says
YT, BOTSWANA
Jefx, i've always been told to use a cold plug in these larger motors. Recently i've been reading the manufacturers are recommending medium, and even HOT plugs. Like the Mach .26. It seems to me its gonna come down to what runs best, and doesnt over heat. Its funny how Odonnell is releasing a plug for all large motors, that only comes in one heat. This glo plug mystery sorta reminds me of the breakin processes. Years ago i was always told to keep an engine really cool during breakin. Then they said to get them to atleast 180-200 during breakin for proper expansion. Now you'll read some manuals reccomending a wide open throttle breakin. For me, medium to HOT plugs work best in the winter. Without them i can hardly get my truck started at the track in the long winter months. Summer time i find the cold plugs work better, or a medium. I guess you could use a medium all the time. I dont really know why Dynamite says to use the MC59 plug. I will have to try one this weekend and see how it runs.
Matt
Matt
I have ran a odonnell 99 and a mc59 in my lst . The manual calls for a 59 but I didn't notice a difference. I did have to retune my engine. And the difference with the engine break in know is the materials that are being used .
Glad to see you approve bashmaster just dont add anything and stuff it up!
I have been running os a5's whith a lot of success, However I'm not sure if this is the ideal plug for the mach 26 it was all I could get hold of here in Tasmania down at the a##hole end of the earth!
Anyone else useing this plug?
jeffx do you know where in the heat range the os a5 compares to the o'donnall you are refering to?
I believe the O.S. A5 is a cold plug. It's also a short plug.
I don't like using short plugs, because it reduces compression. Since it's shorter, the combustion chamber actually becomes larger. The ODonnell, LC3, MC 59, MC8, and MC 9, are all long plugs.
Since this thread, I actually went back to the LC3 plug. My LHS doesn't carry the ODonnell's, and I didn't really notice much difference in performance from it.
ORIGINAL: greig
Jefx . My lhs only stocks os plugs , what plug in their range suits the lst, Do you know? Thanks
I have run a few different plugs in my Mach 26, but the OS 8 is running SWEET! Stick with it
PA
I used the OS * also throught the fall weather here in PA. It ran great and the engine tuned great. The MC59 was running way to hot for me.
IL
ORIGINAL: icenutz
What fuel are you using? Ive heard that with more nitro, you need a colder plug.
I used 20% Monster HP for about half gallon, breaking it in. Now I switched to 25% Monster HP, still using MC59 plugs and it has been running hot. Its cold here in the Chicago area too! So, I tried putting in a new Duratrax gold plug (short cold plug) that I had in my box (the Savage likes them) and its a little better.
Id just like to find a plug thats the right length, works good and doesnt run hot with 25% fuel.
PA
ORIGINAL: RamSavageLST
ORIGINAL: icenutz
ORIGINAL: greig
I've been using the O.S. LC3 plug. It's a long hot plug, equivelent to the MC 59 (Which Dynamite recommends for this engine). It appears that everyone has their own opinions on this topic, so just use whatever works well for your engine and driving conditions.
SD
Im glad u brought this up jef i had issues with switching plugs!!! I went from a 59 to a mc9 on my last outing (partially due to the mc59's goin out in one tank....could be my old tuning habits???????))) it took forever for me to get the truck to operating speed but when i did it seemd the mc9 was waaaaaayyyyy better even in the colder evening weather!!!! MC59 was running way to hot and would go out at the same settings the mc9 was dead on.......was runnin right at 200 degrees with the mc9 too! jus my observation but i think the colder plug works well nd is a lil more forgiving to newbs.....like me......seems the hotter plug needs closer moderation! I was wandering has anyone had the same results with the 2 plugs?
i used the odonnel plugs when i first got my truck and they didnt last very long and they are exspensive so ive been useing os lc3 and its been working good for me. but every motor runs different in different climates and tuning prefrences.
