Alum. Diff. causing damage?
There has been a lot of talk of Alum. Diff. cases. To all those people with them are you experiencing a damage roll on effect i.e. an increase in broken driveshafts? Certain parts are made to break before others, before I commit to Alum. Diff. cases I thought I'd ask.
ME
yes. certain parts are indeend meant to break before others. the diff cases however are not one of these. they just made the plastic ones too weak. i have the aluminum ones in and nothing has been breaking on the drive train. its actually been weeks since ive snapped a drive shaft. not that the aluminum diff cases help with that. they are a must in the upgrade department.
ORIGINAL: lstman
Teach me how to better [ab]use my truck. I'm on the same plastic set of cases my truck, number 660, came with from the factory. Not a crack or sign of wear.
#3395 put the ally diff case in the front from new (shop only had one) craked my rear one last week end, i feel like a proper LST owner now.
As for #59 & #660 come on guys you gotta try harder!!!
My front diff cracked recently (I was being relatively nice to it that day) and I'm thinking it happened after a jump landing front wheels first with the brakes on. The plastic Diff can't take the shock. Any one reckon they've had a similar experience?
TX
ORIGINAL: wallywally
That sounds reasonable. If you watch my videos I have had the cast aluminum diff cases from day 2 with no issues and trust me, I edit a lot of tape to come up with some clean landings. I am amazed with the abuse the LST will handle. The diff case's are cheap and I was watching a Spurs game while I changed them out. (16.98 for both from NitroHouse)
I just replaced both stock cases with blue alum. , fit well inside and out. This came about after front case shattered at the input shaft bearings. This happened at 1.5 gal. I think the front case cracked early on after break in. This resulted in a loud clicking under hard braking, later under full accelaration if the tires hooked up. The ring and pinion were worn victim of clicking noise I heard. Never was able to see the cracks with diff. installed.. I have faith in the new aluminium ones. I doubt stronger diffs are going to cause a worse weak link. The only drive train failure I've had is spurs and pinions, dogbones. Drillbit shank makes great dogbone, dremel to length and a touch of a flat spot.
