Whats left????
IL
Whats left????
I am hopelessly addicted......... I have 40 series wheels, low profile 40's tires, alum shock bushings, aluminum hexes, pro-line body, MIP CVD's in back, MIP axles in front, stiffer springs, alum shock towers and chassis braces on order and Ti shock shafts. want to get threaded shock bodies and reservoir caps when they become available. Any thing I am missing???? suggestions???
FL
RE: Whats left????
I have that same addiction and chasing every upgrade and race part I can find.
You may want..
Werks power clutch ---> http://werksracing.com/clutch.jsp
Hot racing threaded shock bodies are on eebbaayy
Double 1200 RX pack from onlybatterypacks.com
You may want..
RE: Whats left????
My name is Dave, I am a LST addict........former crack....then smack,,,,,,,,,
*** turnbuckles.....
roll cage
alloy a-arms - a must for jumping
roll cage
IL
RE: Whats left????
Oh yeah I almost forgot, I have the new era roll bar, and dual packs, who has the Werks clutch and do they like it???? what shoes to use for the werks clutch??? any one seen TiNi gears from Horizon yet due out in January???
NJ
RE: Whats left????
HERE IS MY ADDICTION
1 NOVA COOLING HEAD
2 SPORTWRKS CARB
3 GPM SLIDER CLUTCH ALUM
4 CNR WHEEL HEXES
5 NEW ERA SKID PLATES F/C/R
6 CNR BRAKE KIT
7 HOT RACING ORANGE SPRINGS
8 THREADED SHOCK BODIES
9 HOT RACING ALUM SHOCK BUSHING
10 HOT RACING PURPLE SPRINGS
11 HOT RACING TITANIUM JET VENT SHOCK PISTONS
12 RC SCREWZ LST STAINLESS STEEL KIT (2)
13 BLACK SPRINGS
14 ALUM GEAR COVER PROTECTOR
15 2 JR Z650 142 OZ/IN SERVOS
16 LUNSFORD TITANIUM TURNBUCKLES
17 SH .28 (GOING IN IN THE SPRING)
SAVING ALL STOCK PARTS TO BUILD AN LST FOR THE MISSUS!!
1 NOVA COOLING HEAD
2 SPORTWRKS CARB
4 CNR WHEEL HEXES
6 CNR BRAKE KIT
13 BLACK SPRINGS
TX
RE: Whats left????
ORIGINAL: motorpsycho502
IL
RE: Whats left????
ORIGINAL: captanabolic
1 NOVA COOLING HEAD
2 SPORTWRKS CARB
4 CNR WHEEL HEXES
6 CNR BRAKE KIT
13 BLACK SPRINGS
1 NOVA COOLING HEAD
2 SPORTWRKS CARB
4 CNR WHEEL HEXES
6 CNR BRAKE KIT
13 BLACK SPRINGS
IL
RE: Whats left????
ORIGINAL: LST2004
How about:
Alum. Diff Cases
23mm Hex Hubs
How about:
Alum. Diff Cases
23mm Hex Hubs
23mm hexes require 23mm wheels, not gonna go that route due to so many sets of wheels I already have.
TX
RE: Whats left????
Well if you are addicted as you say then no stone should be left unturned. How about an SH .28 making 3.6 HP????
Mach 26 is a GOOD engine, will be even better when ported. I am gonna keep it.
IL
RE: Whats left????
ORIGINAL: fourwheeler
IL
RE: Whats left????
Then there's gears,
Low stock is 18/70
High stock is 25/63
optional high is 22/66
optional high is 24/64, both of these options are lower than the stock high gear so now what????
Low stock is 18/70
High stock is 25/63
IL
RE: Whats left????
DANG 4WHEELER I ALMOST FORGOT ABOUT MY SH 28 GOING IN THE SPRING THOUGH!!!
WA
RE: Whats left????
Man, I lucked out I busted out one of my 40 series wheels and just sent them in and they are going to replace them with the 23mm wheels and new tires. All I had to do was pay for the adaptors. The kicker is my best racing tires are at proline and the told me it would take 2 to 3 weeks. Bummer.
I have diff cases also, (see, I have so much I cant remember unless someone else reminds me).
ORIGINAL: LST2004
How about:
Alum. Diff Cases
23mm Hex Hubs
How about:
Alum. Diff Cases
23mm Hex Hubs
TX
RE: Whats left????
ORIGINAL: boogerdan
Yes post the picks. Was this a stong performance change for you and what did you gain?
There is one spring under the nut you turn it in and out to adjust the point where it hooks up (This is when I first put it on and the nut is too tight). The shoes in the picture are Rulon but I have a set of Carbons and Teflon.
Another user gave me this excellent setup link Check out -> http://www.twf8.ws/new/tech/options/...werclutch.html
I think I have gained duribility and I know I have gained adjustability.
Installed with a set of CNR brakes that I received today. I am really impressed with the brakes so far $20 shipped and I ordered on Sunday got them today.
Make sure you have some shims!! I had to use a couple with this setup.
VA
RE: Whats left????
If I understand you correctly you are putting these shims it there to push the clutchbell out some to align better with the spur gears. Is this correct?
Rockman
Rockman
TX
RE: Whats left????
ORIGINAL: Rockman
Rockman
Rockman
Also it is a good idea to have the shims in general for the aligment of everything in the clutch/bell/spur area. I'm sure that and the aluminum cover are the reason my gears look like that after 3 gallons of 30% Rocket Science.
PA
RE: Whats left????
1 NOVA COOLING HEAD
2 SPORTWRKS CARB
4 CNR WHEEL HEXES
6 CNR BRAKE KIT
13 BLACK SPRINGS
1 NOVA COOLING HEAD
2 SPORTWRKS CARB
4 CNR WHEEL HEXES
6 CNR BRAKE KIT
13 BLACK SPRINGS
HOT RACING TITANIUM JET VENT SHOCK PISTONS? What do they add and could you provide a link.
