Cooling Heads
CA
Ok im looking At thE Bay there are some cooling heads there is one that is the same size as stock then there is one that is jumbo.... what is the advantage??? i know they help the engine run cooler but what else ??? also what other engine heads will fit the mach if any???? any help will be greatly appreciated.....
In this forum a while back, someone mentioned they had that 2nd one, and got about a 50 degree reduction in temps, and were very happy with it. Cheap also!!!
CA
well i saw them on thE Bay do a search for cooling heads i think the big one was like 30.00 buy it now and like 9.00 shipping
the big one is www.acncm.com or http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=5955233725
CNR also do heads - not quite as big, but get a choice of loads of colours and they offer a lifetime warranty (breakage for ANY reason).
then theres nova heads. but i like the look of that massive one
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
CA
Do not lean out your motor because it's running cooler because of a large cooling head.You'll starve the engine of much needed lubricant and seize it long before it's time.Lean it some if you must but never lose your smoke no matter what temps you're running
Peace [8D]
Peace [8D]
FL
i have the american cnc head AKA the MASSIVE one it looks good and runs alot cooler now pinolelst is right u dont want to lean it too much learned that on my first t maxx motor
I have the same as stock size one from the bay and got to say for $30 including shipping to England it is very good, like the others have said it runs cooler but i dont run it leaner.
I think you can do much worse than this one!!
