is it worth it to change to diff fluid?
LA
Hi guys, just got my LST a week ago, and will be racing on the local dirt track soon. Plenty of jumps, turns, etc. I was wondering if there is a noticable difference if I cleaned the grease out of the diff's and went with oil. I know the answer will probable be yes, but I was wondering how much of a difference it will make? THanks.
RE: is it worth it to change to diff fluid?
I went 50k in the rear - 30k in the front.. I noticed a huge increase in traction. I'm considering going 80/50 right now.. I'd like to lock up my back end a little more personally and the front still seems to slip more than I'd like.
OH
I usually see people putting a lighter fluid in the front, and thicker in the back. I'm usually on pavement, what can I expect if I put 50 in the front and back? Will it benefit more if I put a slightly thinner oil in the front?
Banned
ON, CANADA
ORIGINAL: JaysonR
I run on the Street Alot and the Sway Bars Help out alot too, I don't flip it to much Since i put the sway bars on.(Bigger Bars F/R)
i'm also always on pavement and have been looking for the right setup you think 50/50 i wil have to give that a try.
i really don't know what thicker or thinner diff oil does and how it helps could you please explain.
Banned
ON, CANADA
ORIGINAL: bosfan
So the Thicker Oil the more it Locks up.
I suck at trying to write this but maybe that will help a bit? Or someone Can tell you better than I.
sorry but still don't fully understand, do you want your wheels to spin at different speeds or do you want them to spin at the same speed? i know dirt and street are different but i'm just talking about street.
and why do you suggest 50/50? i'm sorry for all the questions i'm just trying to understand this
PA
If you put heavier in the front you will turn better going into a turn. If you put heavier fluid in the rear you will turn better out of a turn.
I put 50 in front and 30 in rear. An improvement over just grease. But, I do have other upgrades that could of contributed so I can not credit it all to the diff oil.
IN
I strickly bash on my LST and am running in grass and dirt mainly. In the front I have 50k and the rear has 300k and it is just knarly now. 300k is the near equivelent of peanut butter. I almost had to push it in to the diff. I use regular lithiam grease on the ring and pinion.
