help!!! input for locking diffs.
WI
i was wondern if anyone has locked there diffs for bashin around. i think im gunna do this because i hate drivin around and get stuck and only the two wheels with little or no traction are goin but the wheels i need to be digin into the ground dont move.[:@]
if you havent locked them are you running a thicker oil like 120k or 100k.
i think i might use this, http://www2.towerhobbies.com/cgi-bin...?&I=LXFTY0&P=7 because its realy thick and i can take it out and put thiner in for racing.
I don't think I'd lock the diffs unless you're rock crawling or something. Just try going to heavier oil. What weights are you running now?
WI
its gunna be about 3 to 4 weeks before i even get an lst but when i run my other trucks it does that.
that assoicated 300k weight should do what i want it to.
im sorata rock crawlin with it but in hilly dirt areas where i loose traction on 2 wheels. like 2 are in the air and spinning and the other 2 that should be doin something dont and then i have to go get it.
WI
im gunna wait until i actualy get the lst and see how good or bad it does stock then go from there.
btw what wieghts are you running for bashing around
Can't really say how the stock diffs would run, they just have grease in them. I changed to oil before I even ran the truck, 30k front 60k rear. They'd probably slip pretty easily.
If you really want them locked you might try this stuff: http://badhorsie.com/products/diff-lock-grease.html
Banned
ON, CANADA
I would wait till ya get the Truck and Try Low gear,
But if ya want to 'Lock' them this is the Real way-
http://www.vertigoperformance.com/products_Lockers.html
WI
thows look good. but i dont want to spend more money on them. im gunna buy 60k fluid and fill front and rrear with them first
