gearing
MB, CANADA
RE: gearing
Unless you had a motor with unlimited power, then higher gearing would excellerate faster am I right?
Well I mean if the motor reached the same RPMs at the same speed either way you gear it.
RE: gearing
it depends what you mean by higher gearing. TECHNICALLY i think higher gearing makes acceleration faster. but common sense tell me higher gearings makes it slower acceleration (like trying to accelerate from dead stop in gear 4 in a car or something).
smaller pinion and bigger spur means faster acceleration but slower top speed and visaversa
ON, CANADA
RE: gearing
taller gearing means more acceleration, even thought it sounds like it means more top-end (and most people use it the wrong way)
The word taller means difference in numbers. if you had a pinion with 10 teeth and a spur with 60, the ratio would be 1:6. But if you had a pinion with 20 teeth and a spur with 60, the ratio would be 1:3. So the taller one is the first one, 1:6, because the numbers are farther apart on a number line. And a ratio of 1:6 has (theoretically) twice the acceleration and half the top speed.
My Feedback: (-1)
RE: gearing
is there some type of chart that explains your ratio for the gearing you have likewhen you say 10 pinion and 60 spur =1:6 . i just wanna fully understand what im doing. dont know much about gearing.
ON, CANADA
RE: gearing
I don't know about a chart, but there probably is one somewhere. All you do is set up the ratio of teeth 10:60 - 10 tooth pinion, 60 tooth spur, then you divide teh smaller # by itself and the bigger # by the smaller # and you get 1:6. with a ratio of 24:78, you divide the smaller # by 23, then the bigger # by 23 and you get 1:1.25
Or some people divide the numbers so you get a ratio with all whole numbers. so 24:78 would be 4:13. In this case I found the smallest number that goes into both 24 and 78, which is 6, and I divided both numbers by 6.
Hope this helps.
Hope this helps.
CA
RE: gearing
Hello Sgt Canada...Just looking over the gearing talk here. In my old car club days when someone ran a 4:11 rear end gear he would be able to accelerate quicker but have slower top end than someone with a say 3:78 rear (slower acceleration,more top speed). Any way my take is in RC racing what is important is better acceleration than top speed. All the slowing and speeding up at a track where there usually there are not real long straight aways would call for quick accel and slowing rather than a long sustained speed run. DBM [8D][8D]
