Diff ?
VA
What is the best weight lube to put in each diff for the best performance on the track? 30,000 in the front and 50,000 in the rear or the other way around? Or what? Thanks for you time and input on this mater
i was told 30k in the front 50k in the rear is that what most common lube??? this what makes the most sence to me and i will do unless someone tells me different.
i meant what is the most common diff lube weights 30k in the front 50k in the rear that is what i am asking should i do this ratio??? or is there a better ratio???
tom
tom
Here's the easy way to look at it.
The higher the number the closer to locking diffs you get. The higher in the back the more overstear the higher in the front the more understear (Relative to standard grease and assuming that the other diff doesn't have the same thickness of fluid).
I run 30 in the front and 60 in the rear because I like for my cars to be a little on the nose(overstear). It all depends on what you like. Experimentation is the key! HAVE FUN!
