OK BOYS LETS SPEND 600.00, HELP ME NOW
MO
Fist off thanks to you guys who replied to my 60.00 post, my birthday is coming so im gonna lay down about 600.00 on my lst(gosh i love this truck), i already have the rpm arms and diffs, now I would like maybe some bling or stuff that might make it stronger in a sence and im happy now with the motor and pipe, ok boys break it down for me, yes im asking you too help me build my lst
OR
RE: OK BOYS LETS SPEND 600.00, HELP ME NOW
Just remember no matter how strong you make your truck, you have to decide where the giving is going to take place, it can give on a exspensive part or it can give on a cheap, and easy to replace part once you get past the growing pains this truck is a BLAST!!!
ON, CANADA
If you really want strength, get the HCR titanium chassis. You might wnat teh RPM gear cover also, it looks cool. Get a sprotwerks 9mm carb, and a supercharger [>:] get 8man's pinions ([link=http://www.lstcentral.com/modules.php?name=Forums&file=viewtopic&t=997]read this[/link]) and threaded shock bodys. And maybe even a CP2 body, and BRT1's.
BTW, I was kidding about the supercharger IMO they don't do any good.
MD
flextek suspension arms (only the bottom ones... dont order the whole set. Its too heavy). I'm running bottom flex tek's on the bottom, stock on the top.
aluminum diff case(s)
threaded shock body
stiffer springs (I like 7.4lbs... your mileage may vary however)
CF chassis / upper shock supports
aluminum steering knuckles are nice as well.
also if you go viscous in your diff's you can help keep steering crisp by upgrading your steering servo's.
One things about the LST.... once you start upgrading moding.. Its hard to stop. killerhobbies.com will become your best friend.
threaded shock body
MO
hey nebula8080 thanks for your replythats was a good list of stuff, I wish the others would give more up-grades for the amount I said
ORIGINAL: LoSiSuPeRtRuCk
dont get the threaded shock bodies, they dont even screw on to the caps[:@]
ORIGINAL: alvinm
I have threaded bodies with stock caps they work fine,what do you mean?
Personally, I'd buy a second LST. Honestly.
If you check the auctions, you can find some killer deals on used pre-hopped up LST's as either full runner's or even a project roller. You'd get alot more for your money that way. Used R/C's usually only go for about half of the total investment, so you could get a whole truck (valued at $600) hopped-up with up to an additional ~ $600 worth of stuff for around $600.
[link=http://cgi.ebay.com/Losi-LST-truck-4WD-Not-T-Maxx-Ofna_W0QQitemZ5990156078QQcategoryZ44028QQrdZ1QQcm dZViewItem]HERE'S[/link] a good price going for a project roller, and since you already have a radio, all you'll need is an engine.
[link=http://cgi.ebay.com/Losi-LST-gas-monster-truck-not-Revo-Savage_W0QQitemZ5990375494QQcategoryZ44029QQrdZ1QQ cmdZViewItem]HERE'S[/link] one with several hop-ups, and you could sell the radio back on Ebay and still have money left for even more hop-ups.
[link=http://cgi.ebay.com/LST-losi-with-carbon-fiber-kit-titanium-kit-hitec-A_W0QQitemZ5990218523QQcategoryZ44029QQrdZ1QQcmdZV iewItem]HERE'S[/link] another with several hop-ups.
[link=http://cgi.ebay.com/Team-Losi-LST-w-Hop-ups-and-Custom-Body_W0QQitemZ5990438663QQcategoryZ44029QQrdZ1QQcm dZViewItem]HERE'S[/link] one that's pretty PIMP.
And I'm sure you can find many more.
ON, CANADA
that last one is a IST (integy super truck)
But Dapicco, if you're okay with a used one, it's a pretty good idea or at least it seems so to me. Good idea jefx!
Good call JefX, I did just that...bought a roller with a mach that was done up very nicely (TSB,CF,23mm,Hard Ano everything, Hitek 645's etc etc for $475. All i tneeded was radio, so I bought an RS310 and now have two trucks. Only one lot of spares to keep up with, but the worst part is when something great comes out for the LST, I have to buy two of em
OH
your building an lst
so picco .30 rpm a arms, lunsford hinge pins and turnbuckles, dynimite pro linkedge, ofna meduim clutch, threaded shocks bodys, nitrid grears, aluminum diffs, 525mg servo from hitec, new era roll bar, 525bb high torque for stearing, and dynimite alumiinum shock towers and bell crank
