newbe here
newbe here
after reading alot of the post and look at alot of your trucks i see what looks like wire ties on your cooling heads. what are they for ???
cr250
cr250
RE: newbe here
If you run the stock body on the LST, they are not necessary. Running the LST Naked does require the use of the ties. On a Savage, they are necessary as on-pavement flips will demolish a head in short order.
