four-stroke for lst?
RE: four-stroke for lst?
In order to get the same amount of power, the 4 stroke would need to be MUCH larger. Most Weed wacker engines produce around 1hp, but significantly more torque than a Nitro engine. Bigger engine=more weight. Search for posts relating to fitting a weedwacker engine in a T-maxx by Dr. Honda. He did it, but he had to fabricate several items. If you can do the fabricating, maybe you could pull it off. The question is why? It might be cheaper and would be much easier to go to 1/4 scale trucks or 1/5 scale like the Nitro Hammer Buggy - it has a weedwacker engine.
UT
ORIGINAL: Nitronutt
OS makes a 4 stroke engine whether it'd fit or not who knows. Also another option is trying to fit a Airplane 4 stroke into it....cooling it however will be a issue.
ORIGINAL: badz
a 23cc weed wacker engine produces around 2.5HP stock with a big bore kit stepping it to 27cc it'll produce around 3.5-4HP. This is with stock carburator and exhaust and zero porting. Add a tuned pipe, better carburator and do some porting you can easily hit 6+ HP and isn't a Nitro around as durable or with the power and torque of a gaser. The drive trains of Nitro's won't handle a gas engine. Dr Honda's TMaxx is majorly modified for it.
Like I said, 1/4 or 1/5 Scale if you want gas (Most of those are 2-stroke, though, not 4-stroke).
PA
i hadn't considered the effects of torque on the driveline or the reduced operating rpms on speed. no way am i gonna 'reinvent the wheel'. my lst is quite capable of breaking itself without my help.
anyway, thanks for the thoughts.
IN
I wouldn't even think about putting a 4 stroke in a vehicle unless it is a 1/4 or 1/5 scale. even though i would like to see a nitro engine of that size (Lets say about 12 hp for a 23cc engine).but 4 stroke's lacks the rpm (But have great torque)to be suitable for a 1/10 or 1/8 scale vehicle. Considering that 2 stroke has an average of 35,000 rpm. 4 stroke has an average of 25,000. i use to be into planes but 4 wheels are for me
Hey guys, I don't have an LST but I thought you might be interested in my project:
[link=http://www.rcuniverse.com/forum/m_3111122/tm.htm]http://www.rcuniverse.com/forum/m_3111122/tm.htm[/link]
I had to gear it up a lot but it still has plenty of torque. The added weight has broken just about all the plastic parts but with aluminum A arms, steering linkage and chassis braces it is holding up well. The pics are old and I have a new Saito 182 motor in it. Also the Savage shocks were breaking like toothpicks so I went back to stock CEN shocks, I'm waiting for the new CEN aluminum shocks.
My Feedback: (8)
MI
ORIGINAL: OFNAMAN
Of all the 4 strokes I have had, none went much more than 10,000 rpm. The valve train cannot stand much more
A 4 stroke in the .70 to .91 range might make for an interesting project. Gearing would be a problem since a 4 stroke in this range is generally limited to 10,000 to 12,000 RPM's max. You would just about have to exchange the pinions and the spur gears with each other to make up for the RPM loss, well not quite, they would wind up being about the same size. You could add a battery driven fan for cooling. The Xtra large tank would power it for several minutes cause fuel consumption might not be that bad. You might need to lay the engine over partially on its side since the 4 stoke is much higher.
Interesting project. Go ahead and build it and let us know how it comes out.
Ed M.
Ed M.
