Losi Monster Trucks Discuss all Losi Monster Trucks (i.e. LST) in this forum. Optionally you may discuss this and all other MT's in our general MT forum.
Broken diff
Old 12-29-2005 | 05:17 PM
Wisconsin Nitro's Avatar
Default Broken diff
i need to get a new rear diff
is this the right one?
heres the info off of the site
Front/Rear Diff Bevel Gear Set: LST, LST2
$7.00 [LOSB3538]
Old 12-29-2005 | 05:32 PM
2DMaxLST!!'s Avatar
Default RE: Broken diff
That is correct for the syders. Have you taken it apart?? Are you sure it is bad?? How do the ring and pinion look??
Old 12-29-2005 | 05:56 PM
jefx's Avatar
Typically, those spider gears will outlive the ring and pinion by a large margin. Have you tried to just shim up the diff?
Old 12-30-2005 | 02:00 PM
actualy i just found out it wasent the diffs
turns out those screws that hold the shafts onto the drive train were losened so it was just spinning on it
so.... PROBLEM SOLVED!!!
thanks for the input though
Old 12-30-2005 | 04:59 PM
2DMaxLST!!'s Avatar
I was gonna say, I've never lost a diff!!! Of course I'm heat cycling a RE SF .32 right now so, who knows!!
Old 12-30-2005 | 05:09 PM
A.B.U's Avatar
OMG. You just got the OS 30VG too?? I hear the RE SF .32 produces massive power. Lol... as from pleco.
