glow plugs onlst 1
glow plugs onlst 1
hi ive gone throw 4 plugs to day im running os n8 plugs 16% tornado fuel not runing rich or lean the engine seems to not to tick over . my m8 runs the same set up as me and has no problems only thing he has is a high tick over and fuel pipe that runs behind the fuel tank then to the carb ( not as you get it stock ie near the engine ) wot can the problem be ? do you think as the fuel pipe is near the engine it is geting preheated before it gets to the carb or is there a nother problem all together.
RE: glow plugs onlst 1
If it not cuased by a lean run, or multiple high speed long distance runs, I would pull the head button and rear plate to see if something is going wrong inside the engine. Any metal that is wearing off inside the engine can build up on the plug causing its quick death.
Ed M.
Ed M.
