twin receaver packs
twin receaver packs
hi i keep hearing about useing twin battery pack but were do you fit the second battery if you got the large tank
RE: twin receaver packs
If you get the high capacity fuel tank, you can't mount the 2nd battery where it should be. Some people ziptie or velcro the battery to the receiver box, but that may upset the F to R weight balance. I recommend getting a 1400mah battery and not worrying about it. A 1400mah battery will last several tanks, so plan a time for charging after 4-6 Tanks (Just to be safe).
I bought the last 2 flat pack 1400 sticks my LHS had. They told me those aren't being made anymore... something about a problem with the cells. Can you still get them, and if so where?
NM, I found lots of them... need to speak to my LHS!!!
My Feedback: (-1)
Well do what I do. Get 5 AA 2500 MAH rechargable batteries, and make your own receiver pack. I'll let you know where to mount it once I've figured it out
Banned
ON, CANADA
ORIGINAL: mayhem maniac
I Plastic Dipped it To keep it Water Proof...
Banned
ON, CANADA
ORIGINAL: silverado2000bg
what kind of servos do u have SublimeJason i saw that they were blue are they stock or did u just paint them?
Banned
ON, CANADA
and does the higher number on the reciever is how fast they react or not?
Banned
ON, CANADA
Good idea, although that looks like a 4 cell, which isn't enough juice for me. I need to have 6 volts, or more. I will post my results on putting it under the tank. A 5 cell I mean
I Said its 5 GP 2500 AAs Like how Hard it that to Understand??
