starting lst2
IN
starting lst2
when i start my lst2 i have to give it a lil throttle for it to start and then when it is cold it won't take off w/o dying a couple times before it goes. After it takes off the first time it runs idles and takes of great. do i need to adjust my low speed screw and if so leaner or richer... i have always left them at factory before
thanks
thanks
RE: starting lst2
do the pinch test. get it running, drive around a bit. then come back, pinch the fuel line near the carb, it should raise in RPM a bit and then die. they outline it in more detail in the user manual.
that would be a good start IMO. if that doesnt work, might need to look at the idle screw, but really if it idles ok otherwise, thats probably not the problem.
My Feedback: (9)
FL
RE: starting lst2
Mine starts easy, and I can pull off the ignitor in 10 seconds or so and it wont die...it has 3 tanks of fuel thru it, and the stock plug. It is set at factory brek in settings.
Try to bump up the low speed idle stop....let it idle a bit higher and I would bet it wont crap out on you..
