CAn't decide
CAn't decide
I can't decide wether I should get the muggy or the LST2
I did my homework on them both and I was going for the muggy.
but My question to you is ground clearance......Is the muggies ground clearance and overall size compare to the LST2
because I don't want some sissy truggy
thanx for your help
thanx for your help
1 Post
RE: CAn't decide
It depends what you want the truck for, if you are bashing, go for the LST, if you are planning on racing in the truggy class, go for the muggy, if you are going to be racing and bashing or racing in the MT class go for the LST.
The Muggy is slightly shorter in length and width than the LST (just a quater of an inch or so each way) but the ground clearence is the ground clearence of a truggy, whereas the ground clearence of the LST is the ground clearence of a MT.
Hope this helps some
CA
RE: CAn't decide
The muggy has a plate chassis like a 1/8 scale buggy the lst2 has two side rails and a top and bottom plate that give it more ground clearance in the center so I second what Bkag said and to add to that the muggy should be better in the turns due to a lower center of gravity.
