highest mah battery type for lst2 ...
TX
[link=http://www.amainhobbies.com/product_info.php/cPath/1_221_224/products_id/7001]I sourced mine here...[/link]
ORIGINAL: 2DMaxLST!!
that battery is a lot heavier than a regular rx pack?
NY
http://www2.towerhobbies.com/cgi-bin...?&I=LXNMD6&P=7 this is a good pack
TX
I have and use a Duratrax ICE charger but I use it for everything from charging my glow sticks, AA's, Rx packs and even the LiPo battery in my mini-lst.
http://www.duratrax.com/caraccys/dtxp4170.html
What kind of price tag does that have? Is there anything in particular wrong with the wall charger that comes with the LST2? I just had my battery go bad. It was charging, the the light went out, now it has no charge at all. I used my buddy's charger and there was no light on his, with my battery. Horizon is sending me a new battery. Do the higher Mah batteries make the stock servos seem more powerful? Thanks for the help!
speaking of batteries... I just bought my first RC, the lost LST. I bought a 1600mah receiver battery, which comes with a 100mA charger.
I've charged it up for the first time, and I have used it for about 5 tanks of gas. I have no idea how much charge is left in the 5-cell receiver pack, so should I just go ahead and trickle charge it with my 100mA charger overnight? What happens if the battery pack dies, is there a failsafe that will turn off the throttle? How can you tell when the battery starts to get low on power and needs to be charged?
Thanks!
Thanks!
CA
always charge your battery after you use if for a while. my battery lasts a long time too, but i try and charge it after every use so i dont have to worry about a run away.
