Muggy Pro!!!
Muggy Pro!!!
Well after looking and looking and looking i might make my muggy a real racer!
My track lets the use of .30's
List of upgrades:
werks racing monster clutch 59.93
Losi shock spring yellow x2 10.79
losi AL> shock body/adjust set 47.30
Monster s-1600 28.85
Rc raven aluminum braided fuel lines 19.95
Rpm a-arm balck 46.05
Rpm arm adapter 4.21
losi vented 13t clutch 12.44
losi high temp brake disks 14.10
STS racer nine .30 w/tuned pipe 194.90
Don't know what type of wheels to get? the track run's hard orange clay
List of upgrades:
TX
RE: Muggy Pro!!!
I can't imagine how you could possibly race with yellow springs on a Muggy.
I've been running Werks clutches since I got my LST in late 04' with outstanding results but my Werks clutch did not last long in the Muggy platform.
If you purchase 'Rc raven aluminum braided fuel lines 19.95 ' before you own a set of the LOSI -15 degree caster hubs, well that does not make sense to me.
If you are going to run RPM a-arms you should get a set of Lundsford 40mm Ti links at the same time.
I am running the stock shock bodies.
I would get a 12t clutch bell to get the gearing more inline for R/C dirt track racing.
Just my thoughts.
Just my thoughts.
RE: Muggy Pro!!!
Hey 2d how would u setup the muugy? what engine, clutch, metal, how?
if u got the time can i get a list of parts i shoud get for the muggy? i spend 500-600
RE: Muggy Pro!!!
Hey 2dmaxxlst is this a better setup?
Rpm A-arms balck x4
Rpm arm adapter
Vertigo Performance single 3mm carbon fiber disk brake x2
MONSTER S-1600
OFNA Picco .28 engine
12t clutch vented
New Era blue aluminum C hub
New Era blue aluminum steering knuckles
New Era LST2 silver aluminum rear knuckles
Air Cleaner
HD Alum Clutch Shoes & Springs, Gold: MUG -
Vantage Racing carbon fiber 1/8 pipe
this setup any better?
Rpm A-arms balck x4
Rpm arm adapter
MONSTER S-1600
12t clutch vented
Air Cleaner
TX
RE: Muggy Pro!!!
My order of upgrades for the Muggy are:
(for racing do RocketRon's setup)
1. Fironi (spelling) clutch (I run carbon shoes with 2 HD springs)
2. Single High Torque Servo
3. 12T vented clutchbell (Muggy is over geared)
4. MT, MTR, Maxx or GRP racing sized rubber.
5. -15 degree castor hubs from LOSI
6. Bump start backplate and single piece engine mount. (you will need a starterbox)
My opinions on your list, all my opinion of course...
Rpm A-arms balck x4 -- I have these but have not installed them
Rpm arm adapter
Vertigo Performance single 3mm carbon fiber disk brake x2 -- I still have stock brakes
MONSTER S-1600 - I bought a extra stock from ebay for $12 I stick it in for mains and use the other for quals.
OFNA Picco .28 engine -- learn to drive with the stocker, it has plenty of power
12t clutch vented -- should be top of the list
New Era blue aluminum C hub -- waste of $$ get LOSI -15 degree caster version
New Era blue aluminum steering knuckles -- I've broken one, by hitting a fence at WOT, still run stock
New Era LST2 silver aluminum rear knuckles -- complete waste of money, no added benefit at all, just dead weight
Air Cleaner -- no added benefit, stocker is fine
HD Alum Clutch Shoes & Springs, Gold: MUG -- same as stock, will fail quickly
Vantage Racing carbon fiber 1/8 pipe -- my stock pipe has worked well with a RB-C6, LRP Spec III, Mach427 and a modded Mach .26
Rpm arm adapter
RE: Muggy Pro!!!
2dmaxxlst where can i find that clutch? what servo do u recomend? can i get the tires from tower?
a link would be helpful.
What engine do u recomend? axial .28, picco .28, and what starter box would be good for theh engine and muggy is the rpm arms nessaory?
i can shop at killer and tower and depending on the clutch site?
tower is just easy for me.
RE: Muggy Pro!!!
2d races his muggy more than most of us and does well. Any advice he gives you is spot on. You want a good motor for a god price, here is link.
http://www.speedtechnitro.com/ebprod...nid=68&id=6973
The losi 15 degree casters he recomends improve the handleing alot. A Vented CB is a must, either 12 or 13 tooth. But you definately need a clutch. Fironi seem to last longest but HPI makes a purple aluminum clutch that I have run for 6 gallons. Here is another clutch that people recomend and even team losi suggest
http://www.speedtechnitro.com/ebprod...id=632&id=7446
I have the rpm arms. If I got them again, I would only do the front as I have taken all the camber out of the rear.
If you are looking to make a solid racers at a budget, here is what I would do.
1. 12 tootch vented clutchbell and 1 of the three clutches mentioned.
2. Tires, switch to maxx size or MTR, You will need to convert to 17mm hubs. I recomend hpi 17mm hubs and a set of HPI nubz tires. They are good grip om allmost any track. And they come pre-glued
3. a good single stearing servo, I did a JR 8550
4. Use stocker motor till you get used to truck, its plenty of power and speed. If you want to switch, I would go to axial and get the $20 backplate to convert it to bump start and use a starter box. The sportwerks 1 piece motor mount is low enouph to do this, but I had to dremmel one little spot to get flywheel to clear the mount. Losi makes a mount also, but I had converted already before it came out.
After that, you have a solid truck that can hold its own anywhere. Anything else is just optional. I did RPM arms, and a new pipe. Both 2d and I have TQ'd at local tracks with our muggys against the high dollor jammins and Kyoshos
RE: Muggy Pro!!!
ok is this better than before?
Axial .28 Spec 1S Engine Green
Axial Easy Start Back Plate .28/.32
HPI Vented Racing Clutch Bell 13T
HPI Aluminum Clutch Shoe 3 Pc Type
Robinson Racing Vented Alum Flywheel 3 Shoe Prp Sav 25
HPI Hex Hub Adapter 17mm (2) x2
HPI Nut M8 (4)
Hitec HS-985MG Coreless Ultra Torque HD MG Servo
HPI Nubz Tire/Dish Wheel Yellow (2) x2
HPI Nut M8 (4)
RE: Muggy Pro!!!
Here is a couple pics of my racer. I can keep up with any truggy out there no problem.
List of mods.
1. HPI clutch finally went after 6 gallons so trying the dynamite maxlife
2. Ofna CB shim kit with 12,13, and 15 tooth hpi vented flywheel depending on the track.
3. Chasis bracing useing revo tierods
4. RPM arms
5. Diffs 50 center, 30 front, 10 rear
6. 30 wt shock oil with yellow springs in front and black in rear moved to outer hole on all arms. Also removed sway bar from rear and put
heavy one in front.
7. single jr 8550 stearing servo and moved a 590 to throttle/brake with fuel tubing replaceing the springs
8. Craddock disk for front brake and duel disk steal brakes for rear
9. the stearing mod is kind of hard to explain but all he slop is gone
10. sportworks turmoil 1 piece motor mount.
11. LRP spec 3 truggy edition with rb air filter
12. racers edge max speed pipe with shorter turmoil manafold
13. Sportwerks 17mm hexs
14. hpi nubz
15 spektrum radio and reciever
List of mods.
4. RPM arms
heavy one in front.
14. hpi nubz
RE: Muggy Pro!!!
ORIGINAL: 2DMaxLST!!
Rpm arm adapter
Rpm arm adapter
Yo, Do you have a part number for the LOSI -15 degree caster hub for the muggy?
ON, CANADA
NC
RE: Muggy Pro!!!
Kyosho kid you really DONT need a different engine. Have you even worn out the stocker? I have had a couple mach 427s/SW .26 and they make plenty of power even in the LST. As said before 2D's info should be spot on as driven these truck ALOT!
RE: Muggy Pro!!!
I just bought a Muggy and like it but I am having a problem with the motor not staying aligned. It keeps moving on me so that the CB does not contact the spur gear. Is there a fix to this or am I just doing something wrong? I try to get it tight. Also what can I do to get this thing to jump out of the hole? I watch other truggies and buggies and the seem to be alot quicker out of the hole( out of the turns and from a stop). Is there any way to get my Muggy to do this without getting a new motor? Another question is which spring have you run with thw HPI clutch shoes, the stiffer or lighter ones? Sorry so manny questions but I am trying to get this thing to run really strong.
