Losi Monster Trucks Discuss all Losi Monster Trucks (i.e. LST) in this forum. Optionally you may discuss this and all other MT's in our general MT forum.
diff oil
Old 06-14-2007, 04:29 PM
phill200566
Default diff oil
hi guy's what weight diff oil would you recommend in my lst diff's
Old 06-14-2007, 04:45 PM
2DMaxLST!!
2DMaxLST!!'s Avatar
Default RE: diff oil
Bashing or Racing??
Bashing I run 30k/30k or even 50k/50k
Racing I run 30k/10k or 10k/3k
Old 06-14-2007, 05:11 PM
nicotram
you run the heavier weight in the back, right?[sm=71_71.gif]
Old 06-14-2007, 06:09 PM
Racing T
Racing T's Avatar
you can but your truck will have terrible handling and will spin out very easy.
Old 06-14-2007, 06:44 PM
2DMaxLST!!
2DMaxLST!!'s Avatar
Heavier weight up front, seems counterintuitive??
Old 06-14-2007, 07:49 PM
bakersfield basher
bakersfield basher's Avatar
[sm=confused.gif].............?............ Thems big persons words
Old 06-14-2007, 09:06 PM
2DMaxLST!!
2DMaxLST!!'s Avatar
Spell check allows me to try and use big words.
Old 06-14-2007, 10:03 PM
Sugafree
Sugafree's Avatar
ORIGINAL: 2DMaxLST!!
Thats Classic 2D! ....
Old 06-15-2007, 07:52 AM
nicotram
ok, ok, yes, i'm a noob but trying to understand all these big person terms!
I recently changed the stock diff lube and put 10k in the back and front (i think the stock diff lube is about 3k??). My understanding was that if the viscosity of the fluid is higher, then the power transfer to the wheels would be more uniform. ie- both wheels turn at closer to the same speed due to the power being transferred more evenly. If this is true, then IMO, running heavier weight lube in the back should make for less one-sided wheel spin and more wheelies ( i run a lot in loose dirt/grass).
HOWEVER . . . after changing my lube, i noticed the truck seems a little more squirrelly at higher speeds in the long straights. In your opinion, could that be from the diff lube or something else. I should also mention I just put a set of bowties on as well.
Thanks in advance foryour help!!![sm=wink_smile.gif]
Old 06-15-2007, 12:14 PM
Racing T
Racing T's Avatar
try puting heavier diff oil in the front, that will help it handle better, I run 30k front and 10k rear and it works great,
Old 06-16-2007, 04:38 PM
nicotram
thanks, I'll try it and see if it handles better.
Old 07-02-2007, 07:58 PM
buck hunter
2D, you put the heavier weight up front on the muggy also?
