Lets get some pics from everyones rides :D
#327
IL
RE: Lets get some pics from everyones rides :D
Nope , its got a Mamba 8000Kv brushless system , alloy front c hubs and steering knuckles , Losi DD slipper and center diff .
And soon to have an Exotek LXT C/F chassis !
#328
hey 2dmax? i nticed that your shocks have alot of room between them and the upper arm.how did you do that?what is your setup?i noticed you have a different lower mount and it looks like your shock towers are different.
#330
MI
Here is my LST. It is dirty for those of you who don't beleive we use them. Buku Pipe Hex Screws and the rest is bone stock. Pictures are taken with my phone.
#332
ON, CANADA
Buy a LST2 Tranny........Grab an Extra Servo & 3 Channel Radio.....Your Good to go.....(All Stock Items on both the LST 1 & 2)
#333
ORIGINAL: Sugafree
#335
UT
Hey, i'm gonna be getting an aftershock in a couple months...its pretty much an LST2 minus a few better parts, right?...what parts should i get right after i buy it, like parts that break the most and such...i'm only bashing it, until i get better at driving and my track builds and out door track. parts includes any aftermarket hop-ups i should get too. thanks.
#336
FL
dude try and change out the fuel filter I mean you might not have a prob but I did and they are known to have leaks I mean there isnt much you can do to it to make it stronger. But try and work out the little things first like leaks and what not. Cause if not they will cause maxxive probs. Ohh and change the throttle linkage to the LST2 set up much better on the break and gas. I mean other then that I have never had any probs with my truck.
#338
hey today i was out bashing my shock pretty hard and the wheel flew off,the nut was still on but the center of the wheel ripped out from the wheel.still works i just switched to the sava 17mm nuts.the ones that fill the gap?you know.yep just dremeled it out and threw itback on.the hex was good,just the very center of the wheel ,the part under the nut.ripped loose from the rest of the wheel.crazy?
#339
AE
2D where is that track you were at i am going to texas in june for 4 months and need some where to race. thanks
i will be in whichita falls (for give the spelling)
jake
jake
#342
I needs some action shots but this was taken around breakin, no holes in the windshield even.
[img]<a href="http://s104.photobucket.com/albums/m174/aiden_nicholas/?action=view¤t=IMG_0974-1.jpg" target="_blank"><img src="http://i104.photobucket.com/albums/m174/aiden_nicholas/IMG_0974-1.jpg" border="0" alt="Photobucket"></a>[/img]
#345
TX
Some recent shots of my LST taken at RCHeadQuarters (formally Toys4BigBoys) by the owner Robbie!!
Video: 14minutes on a tank (warning 81meg)
I went to the track last night to run my RB928 and see how long it will go but I need a new OWB for it.
I pulled my backup Mach427 out of a tuber ware container and without tuning dropped it on the track and make this video.
I am of course running the stock LST2 220cc tank and Werks 30%
I am running a Teal Mach427 with the Dynamite Platnium Series 3 needle carb and 7.5mm insert with a Dynamite 053 pipe.
The truck has the FOC gear swap and +1 pinions, will put on the stock pinions before racing.
Gators, not 38 series, on non offset Jconcept wheels with 9mm offset DACE hexes
#347
Nice vid 2D, the little kid with that electric thing was funny. I have a tuning question for you though. I watched that whole vid and I never saw once that it got too lean twoards the end of the vid. The idle was a little higher but it wasn't extensive. I have been trying to get the tune down when it comes to the end of the tank, and when I get it good at the end of the tank, I fill it up and its pretty rich. A little too rich for my liking. Is this what you do when it comes to the end of the tank? This is for my Revo btw. Any suggestions?
