Test #1: Failed.
AZ
Test #1: Failed.
So, I took the LST2 out bashing today... nothing really major... just a little dirt fun with a small jump... (only could get 1' off the ground... too soft of a lip)... ended up breaking before even the first tank was through... kinda disappointed... It looks like the grub screws came out... dang it... [&o]
Here's some pics of the bash...
RE: Test #1: Failed.
ORIGINAL: RenegadeRevo
AZ
ORIGINAL: LSTVega28
Least your not blowing diffs and tranny gears like on my revo .
For a minute... I thought I did... I noticed I had a lot of power to the rear... and nothing up front... last time that happened... it was a blown diff... then, I realized I had no brakes... on either side... so, I picked it up... noticed the brake disks flopping around... along with the missing grub screw... I was hoping that for $600 I'd have a truck that didn't need to be re-made from the factory.. *shrug* It was very disappointing... [:'(] Oh well... Loctite and new screws should be picked up today... I think I'm gonna go soon to the LHS...
ORIGINAL: LSTVega28
Btw, your daughter is cute!
Every time I have bought an RTR - doesn't matter what brand - I was able to find prolematic areas that would have been addressed with a proper build. That is one of the reasons I don't like RTR's.
PS, did you see the sticky at the top about loctiting the LST2 screws? lol
AZ
ORIGINAL: RCtruckRacer
P.S. Whoever said working on the LST2 was easier than the Revo is full of crap. [:@] Went to the LHS... they don't have the screws... you have to buy the entire cup set (mine aren't broken... and they're still there)... so I didn't buy it... gonna hopefully match it at a hardware store... I don't want to pay $10 for a freaking screw.
AZ
ORIGINAL: LSTVega28
Yes, I did... and like an idiot... I thought a $600 should have factory loctite on it... (the Revo does)... instead of heeding the warnings of my fellow R/C'ers...
Things that are easier to get to on the Revo: Servos, transmission.
Thats about my experience with them both, overall the LST2 is easier to work on. Just watch out for the typical Losi 'loose screw syndrome' and you'll be fine
AZ
ORIGINAL: ccalum02
Things that are easier to get to on the LST2: Diffs, shocks, slipper clutch and spur gears, clutch and bell, carb. All motor adjustments are easier too.
PA
I have had a few problems with my lst2 at first but now after I got it taken care of I'm very happy with it. I don't think it's easy to work on at all, but I own a MGT and that is cake to fix. the LST2 is very impressive with the size speed and handling and I know you must like the radio system. I hope you have fun and don't let your doughter drive it to later. my little girl is 7 and she want's to play with my trucks all the time so I give her the savage (it takes a beating) and tell her keep it close to you and don't go to fast.
In my experience, the shocks are easier to adjust and get to... but not as easy to put on (due to the rounded end balls vs. Traxxas flat end balls... I'd take a picture... but I don't want to have to cuss at my LST2 again... LOL) spur gears... clutch and bell.. not so much the slipper, 'cause on the Revo, you can just put a wrench on it... and adjust... you don't have to take off a plate... and not the carb... neither are the motor adjustments (pain in the behind to get to the LSN)... the driveshafts on the LST2 are much harder to take out... and line up with the brakes... I haven't had to take out the diffs yet... but I can see how they would be easier... since they're at least visible.
ORIGINAL: ccalum02
Don't get too annoyed with the Losi tho, give it time to become familiar. Give it time and let the motor bed in, get up to its prime and you'll like it I promise
Really nice action shots btw
My Feedback: (13)
KY
Hey Renagade,did you have it broken in yet and if so how did you like the way it ran and handled before it broke.Or did you get to run it enough to get a feel for it
AZ
ORIGINAL: gasfreak
TX
I would be disappointed in a hobby shop that does not have 5mm grubs in stock.
You should always check the grubs on a all metal drive train, I know this is your first but it is common knowledge.
AZ
ORIGINAL: ccalum02
Lets agree do disagree then, I've spent equal time working on the Losi and Traxxas and overall they're both pretty easy to work on for me. I know the rounded balls you're talking about and they push in easier imo than the traxxas ones. You know theres a little removeable cap in the spur gear cover to allow instant slipper adjustment right? I've not touched the LSN since first tune so cant comment on that really, the HSN is easy to get to tho.
ORIGINAL: ccalum02
AZ
ORIGINAL: 2DMaxLST!!
As I do appreciate your condescending tone, I did know it... I just didn't do it... I expected the quality of the truck to be as such that I didn't need to (again.. despite the many warnings from my R/C colleagues)... alas I was wrong. Heck, even Traxxas puts thread locker on their drivetrain screws...
AZ
Just a personal request; it's a lot easier to read if you would omit the ellipsis marks. Please?
TX
You should get the good loctite for less $$ at a auto parts store, I get mine at autozone. I don't consider drivetrain screws loctited till I have done it myself.
AZ
And get some activator... too - it makes the loctite... cure within a few minutes. Also try asking for a set screw... and not a grub screw. Not everyone... will know what a grub screw... is. lol
