Haven’t run my trucks for a while…what should I do or know?
The last time I bashed any of my nitro trucks was in the beginning of the summer. I am going all through the trucks checking things. (electronics, tranny, linkages, ect) Is there anything else I should know about or do before i start them again?
PA
RE: Haven’t run my trucks for a while…what should I do or know?
if you're truck uses an internal 1-way to start it, then check that, if they soak in fuel for a while, sometimes they need to be cleaned or else they will slip. other than that, maybe look at your breaks
ORIGINAL: full maxx
a little after run oil would help a dry start
same here, getting back into the hobby pretty soon. I have 2 lst's so I think after run oil and some lube would be a good idea.
ok, thanks guys. I sould be able to get them out soon. And the fuel i use has after run already in it.
