Titanium VS. Steel Density - finished conversion
PA
in science right now, we're learning about density and finding density from mass & volume and finding volume from mass & density ect. and so i decided to bring in another practice problem and that's finding the density of titanium, comparing it to steel, and finding a conversion percentage from the weight of steel to titanium. since i haven't been able to weigh my titanium samples yet, which i will do tommorow and this whole conversion will be completed.
10/11/07:tommorow all of this information will be complete10/12/07:today i weighed the parts
to find the density of titanium, i found all of the measurements of my inner hinge pin which i got from lunsford. first, i found the diameter, which is 4mm, 0.4cm, and the leingth is 70mm, 7cm so to find the ammount of cubed centimeters (mL's) this rod has, the formula to find the volume of a cylinder is π x r² x h which is pie times the radius squared times the height of the cylinder.
1mL = 1cm³
the amount of titanium in two inner hinge pins is 1.759291885mL. and the amount of titanium in two outer hinge pins is 1.055575131mL. so, in my muggy there is 2.814867016mL of titanium per wheel, 11.25946806mL of titanium in all of my hinge pins combined.
tommorow, in science class, i will weigh all of this titanium which will allow me to complete this formula:
_____12.303g
2.814867016mL =4.370761576g/mL.
the toatal weight of all of my titanium hinge pins is 49.21199998g
if i still had steel pins, then all of the hinge pins in the truck put together would weigh 87.82385087g
This means that by switching to titanium pins, my truck lost 38.61185089g, that's 1.364376357oz. [ounces], and the steel pins weigh 3.103316285oz[ounces]
titanium weighs 56% of steel, so take the weight of a steel object, multiply the weight by 0.56, and you have the weight of the same amount of metal in titanium. if you have a titanium part, and you want to find out the amount it weighs as a steel object, multiply the weight by 1.7846 to get the weight in steel accurately to the thousandths decimal place(1.234 the 4 is in the thousandths place)
1mL = 1cm³
_____12.303g
NC
RE: Titanium VS. Steel Density
holy cow what graduate school do you attend ... dang i was good with math in high school but you lost me on the third sentence lmao
